GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Old 12-15-14, 04:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Replaced battery now Power Windows don't work
Old 12-19-09, 06:03 PM
jbyham
jbyham's Avatar
Default Replaced battery now Power Windows don't work
I had to replace the bulb on my drivers side headlight in my GX and in doing so had to take out the battery. Everything went fine until I put it all back together, turned the car on and now my drivers side window controls don't control the other 3 windows in the car. AND none of the windows are performing the auto down function. If it matters the little green light on the window switches themselves are blinking.
Just to summarize:
1. Took battery out
2. Put batter back in
3. Drivers side Power window switches don't control other three windows.
4. Drivers side switch controls drivers side window
5. All switches control their individual window
6. No switches are performing the auto down function
And yes, I checked to make sure they weren't locked.
Help please. Thank you
Old 12-19-09, 06:05 PM
EyeKutr
EyeKutr's Avatar
Read your manual or search "battery windows"
Old 12-19-09, 06:46 PM
jbyham
jbyham's Avatar
Checked my manual and have searched battery windows, power windows, etc. Can't seem to find anything on a solution. Any ideas?
Old 12-19-09, 08:03 PM
nmmuzykam
nmmuzykam's Avatar
You need to lower each window one at a time by actually holding the switch (not auto up/down) and then raise the window up. You need to do this in the following order (on the switch on each actual door, not the master panel)...driver's, front passenger's, rear passenger's, rear driver's. I may have mixed up the last two, but you will be able to tell since the switches won't work unless done in the proper order...hope this helps! BTW, you need to do this every time the battery is disconnected for more than 5 minutes, for future reference.
engVladi (07-25-18)
Old 12-19-09, 08:10 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
There is a link in the 2nd gen IS FAQ that will help (looks like nm has it above already). May also need to do it on moonroof.
https://www.clublexus.com/forums/is-...isconnect.html
Old 12-19-09, 10:57 PM
slvrpine03
slvrpine03's Avatar
they need to be "normalized" just search "normalize windows"
Old 12-21-09, 06:53 AM
CenterIsl
CenterIsl's Avatar
Ditto on the sunroof - all the way open and hold down a few secs, and all the way closed and hold a few secs (I think). Otherwise it doesn't know where "open" and "closed" are. You'll also have to reset your navigation region.
Old 12-22-09, 05:18 AM
jbyham
jbyham's Avatar
THANK YOU! Great help on this one. You were right on with the fix. Thank you.
Old 09-08-12, 12:01 AM
peteharvey
peteharvey's Avatar
Does anyone know why this phenomenon occurs???
Old 09-08-12, 03:32 AM
ALAN553
ALAN553's Avatar
It's a computer thing so phenomenon are a fact of life?
Old 09-08-12, 04:48 AM
RickC5
RickC5's Avatar
Ha ha! Boy, isn't THAT the truth!
Old 07-13-13, 06:51 PM
jkgsooner
jkgsooner's Avatar
Default Wow. Thanx.
I was trying to figure out what it might cost to order a new master window control set, and this advise worked like a charm. THANX again!
jkg
Old 08-09-13, 02:42 PM
rickvdj
rickvdj's Avatar
Confirmed!
This method did the trick. I did the following:
1. Pressed the START button twice to put the car in the on the ON position (radio on)
2. Went to passenger side pressed and HELD the control button till the window was 100% down, then pressed and HELD till window is 100% up
3. Went back to Driver Master Control and tested.
4. Repeated steps 2 & 3 for rear windows individually
Good luck peeps!
Old 08-12-13, 09:01 PM
Enzoxyz
Enzoxyz's Avatar
Such a silly steps. Good thing I won't be replacing the battery soon.
Old 09-01-13, 11:45 AM
Lindber
Lindber's Avatar
Thanks for posting the window fix after battery replacement. It was driving me nuts until I found your post
Quick Reply: Replaced battery now Power Windows don't work
