Wiring diagram to install gated shifter into pre-98 SC
Old Jun 11, 2008 | 03:18 AM
  #46
JesLet's Avatar
JesLet
Originally Posted by cshank
Big thanks for the return of the pics, and the original hard work of putting it all together.
I'll take donations...
Old Jul 2, 2008 | 01:54 PM
  #47
horent135's Avatar
horent135
Has this gated shift been done in the older model like 95? i would love to do this....
Old Aug 6, 2008 | 07:52 AM
  #48
UTSC300's Avatar
UTSC300
I'm excited , I just bought my conversion from R & J , and Jes I'm gonna have a boat load of questions for you. Hopefully I lucked out enough because the conversion is from a 98 sc300 and my car is an sc300. Don't really feel like cutting any shift linkage. Wiring diagram looks awesome btw.
Old Aug 12, 2008 | 10:27 PM
  #49
Slow Motio's Avatar
Slow Motio
Does anyone know of a larger gated/ungated shifer I can fit into the place of the existing one? I want it to look more like the BMW auto shifter with the leather shift boot. I would just put a leather boot over it but it would look like i'm trying to imitate a manual. I love the way the x5 shifter looks. So Im looking high and low, I might just try to fit a BMW shifter in there somehow....
I am trying to get this look....vvv
Attached Thumbnails Wiring diagram to install gated shifter into pre-98 SC-4793_16.jpg
Old Aug 12, 2008 | 10:35 PM
  #50
Slow Motio's Avatar
Slow Motio
^^^_____
That chit would be so sexy....OMG. Please help. I know someone gots to know. I am goin crazy.
Old Oct 19, 2008 | 02:50 PM
  #51
romeo291's Avatar
romeo291
Originally Posted by JesLet
There 4 locations, pick 1:
ECU
Cluster
Transmission
Driver side kick panel, lower orange harness.
Look for a PINK wire.
I see 2 pink wires on that plug, is it the thin one or the thick one?
Old Oct 19, 2008 | 07:35 PM
  #52
romeo291's Avatar
romeo291
Eh, I ended up wiring it to the single and only pink wire on the middle plug's harness that goes to the middle of the gauge cluster. I was told this was the vehicle speed sensor wire. Can anybody confirm this? My car is a 1992 SC300.
Old Oct 30, 2008 | 09:12 AM
  #53
Curry's Avatar
Curry
CL Folding 25,000
I'm going to be doing this mod in the next few days on my 300. I was able to get one from a 300 from gazi so we'll see how the wiring works out. According to this thread i should be able to reuse the shift linkage as well.
Old Nov 19, 2009 | 05:00 PM
  #54
UpInTheLex's Avatar
UpInTheLex
BUMP... I'm in the process of installing mine.
Old Apr 8, 2010 | 03:20 PM
  #55
dublup's Avatar
dublup
I have a chance to get a gated shifter from a SC300. I have a 93SC400. There is a difference I have noticed in the gear its a 3 on the 300 and a 4 on the 400. Will I have any problems wiring the overdrive. I have read threw the thread and from what I see some say its doable some say its not. Any help before I make the purchase and attempt to do this mod would be greatly appreciated help me out CL thanks!
Old Apr 9, 2010 | 09:07 AM
  #56
UpInTheLex's Avatar
UpInTheLex
If you have a SC400 with 3speed with overdrive trans then the sc300 gated shifter will work great. It has 1234, so 4 will be overdrive on and off.
I have a 99 gated shifter in my 95 sc400.
Only thing I'm missing is a switch to turn trac off. But I pull the fuse and leave trac off all the time anyway.
Old Sep 17, 2010 | 12:21 PM
  #57
chashiubow's Avatar
chashiubow
can someone confirm if a 300 gated shifter would work on a 400? Is the o/d then #3 instead of #4?
Old Sep 17, 2010 | 12:48 PM
  #58
JesLet's Avatar
JesLet
It will work.
Open up the black housing of that gated shifter and understand my wiring diagrams, you should able to compare / modify wires. You could separate the O/D wires if you'd like.
It's a matter of time and understanding.
Old Sep 17, 2010 | 12:53 PM
  #59
JesLet's Avatar
JesLet
*** Once again, open that housing and you should see what wires go with what.
That's how I figured how to wire my O/D. Wire color coding of each of the harness from pre98 and 98+ are similar.
This is not hard, just take time to understand the wiring.
I'm done with the gated shifter, I am looking to do R154 swap.
Old Sep 18, 2010 | 07:54 PM
  #60
chashiubow's Avatar
chashiubow
Did the swap today, and it works fine. 3rd gear is now o/d off. Just need to tab the speed sensor and 12v wires.
Thanks again for sharing the wiring diagrams.
