Tranny Fluid option/opinions for 98 ES
So i looked into the manual, as i was heading into the store to buy some M1, to see i NEED Type T-IV from Toyota...
What do i buy!? I need to know ASAP, as the car is going in on Saturday...
HELP! lol At this point i am safely assuming that ANY 'synthetic that is Type 4' is good? How is this as an example?
and then i come across something like this "for GM vehicles only" ?
Thanks guys for the help as i am about to kill myself sorting **** out for this car prior to its major pre winter & maintenance service!
Anyways, i spent much time reading other forums [toyota truck forums, bob is the oil guy, etc] I talked to a few good friends that are techs.
I came to the conclusion that the M1 would not be worth it in my case. The car has 108k, this will be the first fluid change. With 108k miles, there is bound to be lots of contaminants in the trans, and i did not want to risk running something completely new when OEM oil was always present. With regards to metal shavings, etc in the trans, and did not want to mess around with doing a full flush, nor the 3 week method since, i was not gonna go spend ~45$ [x3] for no reason, when OEM is just as good.
I read much contradicting info, with regards to this oil, since M1 was simply made to a dexron 3 spec with a certain additive that makes it somewhat compatible with T-IV, however not enough to bear the T-IV stamp. The only one i found to be made to T-IV spec and a synthetic was the Amsoil version.
Some stated this change made no benefit in their Toyota pickups, others stated in ran better. So i guess it is proprietary and everyone has their own take on the issue. Personally i wanted to breathe easy and get OEM.
In terms of performance, i am sure it is going to be much smoother, now since, its gonna get NEW OIL!
I did not want to risk anything nor expereince adverse affects by using this oil, and i am glad, since i got 4L [1L x4] of the Toyota stuff for cost. [Half the price of the M1]
Whats in the bag?
I will update to share how the OEM is running.
On the third drain and fill, drain the tranny plug and front differential plug and then change out the gasket/filter.
Do you think I should do the 3 flush process and switch to synthetic ATF? Or can I drive around more and wait some more miles before doing my next? I'm at 80 k miles now.
Then again i am more than positive it will be fine to drive on it, but i am the type of person that will not skimp out on repairs on a vehicle i like. Hence my reasoning.
When you switch to synthetic ATF, the the synthetic stuff needs to go in on each step of the 3 drain and fill process. That's exactly what I did when I came back to the U.S. from Mexico last year and switched to Amsoil ATF (which was nowhere to be found in Mexico and PITA$$$ to import).
On another note: I've talked to a few techs that work for Lexus and they tell me they don't change the tranny filter - they just clean it and replace the pan gasket, drain plug, and three copper gaskets. What do you guys know about this?
Thanks,
Martin
Thanks,
Martin
I proceeded to get a new filter and gasket since, 108k miles [daily driven, NEVER raced] and the oil was brownish, if you looked at it, it still had hints of a dark red in it... Which goes back to what you said, 100k no issues.
As mentioned before, Audi/VW products NEVER require to change this fluid!
Regardless, i got a new filter and gasket. A whole 30$ for this part, aftermarket though, not OEM. And close to 5L of new fluid and she runs MINT! I noticed it is more peppier and shifts much smoother. I am glad i went with OEM fluid.
Like i said before i did oodles of research and you cannot call what a synthetic will do in the future. I saw successful results, only in cars that claimed to have logged <30k miles, but begs to ask, what about after? Premature wear?
My reasoning was simple for going OEM. Did research, found an abundance of ressources that claimed there was no difference in 'performance', second, the car is high mileage, and with time certain components wear a certain way with a certain [OEM] oil, and change that all of a sudden, what will happen? Flow will change and a chance of the shavings coupled with old OEM dino oil, blocking off the guides in the trans, and causing a mess. Another thing i factored in was down time. It would take me an afternoon to do this, and it would be just under 200$ with materials, oil [for the 3 step process], filter/gasket AND doing it myself on my cold driveway. Here i had the car back in one hour from the shop.
-Mike
Martin
