Got a lot of work done today. Boy was getting the harness to fit a PITA. I barely got it to fit without getting the ecu wiring. Also the heater hoses are a real pain if you didnt do them while the motor was out like I did =\.
Other than that its just piecing stuff together and doing little things here and there. All I have left is to throw some tranny and diff fluid in, install the shifter assembly (Do youself a favor and remove this when putting a motor in or out...it makes like 10x easier), and shes ready to fire up!
Also I had a question for a plug located next to the battery. there are two connectors that sit right behind of the battery, one fits fine but the other one is totally different and has a total of 5 wires while the plug thats on my car has only 3. Any suggestions?
Hey Man, nice build. Looks to be going very well. Thanks for the awesome posts, these are helping lots of people all over the place(int, sus, eng.....)
I got a question about those LCAs. You installed the MKIV supra LCAs i see. Do you know if they have the same geometry? Are you still running the stock SC steering knuckles? My pass side ball joint is bad and im looking to replace just that side for now, so i need to know if the sc LCA and the MKIV supra LCA are the same?
I have a 93 400 with a 1jzgte and a w58. Glad to see one more of us! THANKS MAN!
Im not 1 of you guys yet..it hasn't started yet! Hopefully i'll fire her up tonight and see what I got myself into
As for the Arms. The supra LCA's have the same geometry but the bushings are stiffer and not hollow like the SC's are. If your ball joint is out, the supra LCA is defiantly the way to go. Its about half the price as the LCA from Lexus and its an upgrade in performance....a no brainier for me.
Originally Posted by tromly
Great build, see you work a lot at night, good effort, we appreciate the pics !!
Ya its alot cooler over here at night. But the past copule days I've started around noonish and worked till about 11ish
I keep telling myself it will all be worth it when shes up and running. We will see....
Sweet so what do i have to do for the bushings? Do they fit the sc or will i have to modify them? Thanks, This is some weight off my shoulders. I didnt want to pay 590+ for just one.
absolutely nothing...the new arm's come with the bushings already installed. Its just a matter of taking your old ones out and throwing these on. That's it.
Just a word of advice. Take a sharpie and mark all your alignment settings so that when you reinstall them you could put it back to where it was and not be too far off until you get your realignment.
You know...ill be honest. I had the car sitting about an inch lower than it is now. I got sick and tired of the ride quality and slowing down for everything. I'm over the slammed car look and I actually think it looks better with the "just under" 1 finger fender gap. The car rides so much better and is much more enjoyable. I dunno, maybe im just getting old
