08 RX350 20x8.5 DPE Tire size???
Old Nov 5, 2009 | 11:38 AM
lfteeglfr's Avatar
lfteeglfr
Default 08 RX350 20x8.5 DPE Tire size???
Need help choosing tire size. I am torn between 245/45 and 255/45. People are telling me that 255 is too wide.
Old Nov 5, 2009 | 01:58 PM
Seize's Avatar
Seize
Loves Snickerdoodles!
You should be fine either way. 245 will be more flush on an 8.5" rim than a 255 would be. 255 would be only slightly wider. Not sure if the overall rolling diameter is of any importance but the overall rolling diameter of the 255 will be slightly higher that the 245, by roughly about a 1/2" or less.
Old Nov 7, 2009 | 04:41 AM
veleno's Avatar
veleno
The 255 isn't too wide, but IMO does look much bigger. I'd get the 245 but if you can try both tires on then you can decide which one is better for you.
isosunrise
Nov 2, 2020 08:18 PM
lexlude
RX - 3rd Gen (2010-2015)
Jun 15, 2019 12:13 AM
Ruffless
Mar 23, 2011 04:03 PM
cliffud
16
Apr 21, 2006 10:25 PM
LEXBOGGY
Mar 4, 2005 11:37 AM
