All pulled from a 1991 LS400 with traction (Black Exterior / Grey Interior)
Shipping will be added to all prices, email me your ZIP and I'll price up shipping.
- All Relays ($10 each)
- Engine ECU $35.00
- ABS/Trac ECU $35.00
- Inside Fuse Panel ($20.00)
- Passengers front outside door handle, Both rear outside door handles
$30.00 per Handle
- Ashtray w/heated seats & Trac buttons ($20.00)
- Center Vents w hazard button ($15.00)
- RearView mirror (not faded both night/day view work great) $20.00
- Inside door handles (Have all 4 of them) $15.00 Per handle
- All 4 Door lock actuators ($10.00 Each)
- Trunk Lock Actuator($25.00)
- Horns ($15.00)
- Nakamichi Subwoofer ($30.00)
- Nakamichi Amp $30.00 (Fits 90,91,92 only)
- Passengers rear Window Motor & Regulator $40.00
- Drivers rear Window Motor & Regulator $40.00
- Dome Light ($15.00)
- ClockSpring ($40.00)
- Airbag ($35.00)
- Steering Wheel ($35.00)
- Wiper Arms ($20.00)
- Wiper motor ($30.00)
- washer resovoir & Pump ($30.00)
- Fuel Pump ($35.00)
- Fuel Tank w filler neck ($100)
- Power Mirror controls / Keyless Entry on/off switch $10.00
- Cruise Control actuator ($25.00)
- ABS Pump/actuator ($50.00)
- Steering rack (Needs one boot replaced) $50.00
- Passengers Inner Tail light ($20.00)
- Front seats (but they are worn, heater elements and all motors work good)
(Probably too expensive to ship, make me an offer on the motors/components)
- Sunroof Motor ($15.00)
- Front bumper Signal lights both side ($25.00)
- Steering Colum w/ignition + Drivers/Passengers/Trunk Locks and 1 Lexus Key that matches all locks ($100.00)
- Also have various interior trim pieces
- Have glass for all 4 doors ($25.00 each)
- Front Visors Assembly ($35.00)
- 4 15" Alloy LS400 Rims (two with winter tires with lots of tread left)
Also willing to trade for any of the following to fit 1990-94 LS400: Climate control LCD or full unit with working LCD, 1 or 2 Front (pre-cat) O2 Sensors, front rotors.
how about the cruise control servo attach bolts (3 of them)and servo cover to zip 78749? Could also use the truck courtesy light cover..what the PO did with these items we'll never know.
I take it that's a no?
Sorry just noticed this message. Don't have the trunk courtesy light. I may have the cruise servo, do you have a pic of what you need, i'm just a bit confused on exactly which part it is.
