2000 ES300, Brake light (in-dash)
Hey yall, I haven't been having any problems with my ES whatsoever -- I love it, and am thoroughly enjoying it. Just recently, I've noticed that the little in-dash BRAKE back light (when you apply the emergency brake) will come on and off randomly, when the emergency brake is not applied.
I'm not too worried, because I don't notice the car driving any different but I have a couple of questions: Why is it doing this? Could there be any harm being done with this light coming on and off, affecting the car without me knowing? How can I fix this (without going to the dealership)? Any and all thoughts and suggestions are welcome. And as always:
Thanks!
J
Thanks!
J
Don't just add fluid w/o checking the brakes first.
The fluid is low because the brake pistons must go further out to compensate for the wearing/worn brake pads. Check the pads just to be on the safe side, and make sure there arent any brake fluid leaks, especially at the master cylinder or brake booster.
I like to be sure
I like to be sure
Thanks a bunch for the replies guys. I think that's got to be it, because I need a brake job pretty bad. I'm assuming it's both needing new brakes + brake fluid. Would you recommend I still check for any brake fluid leaks? You guys are the best.
Good information guys, will keep this in my memory bank in case this ever happens to me. I just replaced all my brakes and upgraded to drilled and slotted rotors with ceramic brake pads and topped of my brake fluid reservoir. Jem1660, for safety reasons, I would still do a quick check to make sure you dont have any leaks, if your going to take in your car to have the brakes done, they should check for any leaks.........good luck.
I like to be sure
I like to be sure
