2000 ES300, Brake light (in-dash)
Old 11-03-09, 01:51 PM
jem1660
jem1660's Avatar
Default 2000 ES300, Brake light (in-dash)
Hey yall, I haven't been having any problems with my ES whatsoever -- I love it, and am thoroughly enjoying it. Just recently, I've noticed that the little in-dash BRAKE back light (when you apply the emergency brake) will come on and off randomly, when the emergency brake is not applied.
I'm not too worried, because I don't notice the car driving any different but I have a couple of questions: Why is it doing this? Could there be any harm being done with this light coming on and off, affecting the car without me knowing? How can I fix this (without going to the dealership)? Any and all thoughts and suggestions are welcome. And as always:
Thanks!
J
Old 11-03-09, 08:08 PM
eyezack87
eyezack87's Avatar
Brake fluid is low. It should solve the problem if you add some. I had the same thing happen to my 2ES. It was to the point where it would flash on/off intermittently and annoy the crap out of me lol...
Old 11-03-09, 08:34 PM
01LEXPL
01LEXPL's Avatar
LOL! What are the odds! haha this happened to me a few days ago, got some more fluid to top and good to go, so far 4-5 days no problems!
Old 11-03-09, 11:12 PM
Rollin'ES3
Rollin'ES3's Avatar
Don't just add fluid w/o checking the brakes first.
The fluid is low because the brake pistons must go further out to compensate for the wearing/worn brake pads. Check the pads just to be on the safe side, and make sure there arent any brake fluid leaks, especially at the master cylinder or brake booster.
I like to be sure
Old 11-04-09, 12:01 AM
eyezack87
eyezack87's Avatar
^^Haha, good point. Sorta forgot about that since mine were perfect when I did my stuff
Old 11-04-09, 05:21 AM
jem1660
jem1660's Avatar
Thanks a bunch for the replies guys. I think that's got to be it, because I need a brake job pretty bad. I'm assuming it's both needing new brakes + brake fluid. Would you recommend I still check for any brake fluid leaks? You guys are the best.
Old 11-04-09, 11:41 AM
angmedic91
angmedic91's Avatar
Good information guys, will keep this in my memory bank in case this ever happens to me. I just replaced all my brakes and upgraded to drilled and slotted rotors with ceramic brake pads and topped of my brake fluid reservoir. Jem1660, for safety reasons, I would still do a quick check to make sure you dont have any leaks, if your going to take in your car to have the brakes done, they should check for any leaks.........good luck.
Old 01-12-10, 06:28 PM
Russelltw
Russelltw's Avatar
thanks guys, my brake fluid was low also. Dashboard brake Light is now off.
Old 01-13-10, 06:45 AM
mmlex1987
mmlex1987's Avatar
I like to be sure
^Thats exactly my thought as well. Good luck, it should just be a straight forward brake job.
Woodscolby
12-06-09 02:33 AM
garcia5280
04-06-09 04:09 PM
forksports
GS - 1st Gen (1993-1997)
05-20-04 10:09 PM
mcgong
08-15-03 10:59 AM
ripe911
12-12-02 05:16 PM
Quick Reply: 2000 ES300, Brake light (in-dash)
