07 AWD Lowered with F-Sport Springs! (Pics)
you sure the F-Sport has more of a drop than the Tanabe? Tanabe's website says 1.4" in the front and 1" in the rear....F-Sport says 1" inch front and rear. Not complaining that the F-sport will be lower, just goes against everything I've seen on specs.
By the way, I've seen people mention WOT when referring to how the car drives with springs...what does WOT mean, and how does that apply to how the car drives? Thanks
Tanabe NF210: Front 1.1" drop....Rear 0.8" drop (looking at the GS350 RWD line on the chart from their website)
Maybe I'm missing something....
It says 25mm for both front and rear. I guess, you are somewhat right, because the NF drops the front 1.1 inch, which is what, 24.5mm? The rear, however, is 0.8in Tanabe vs 25mm F-Sport. We are talking splitting hair here.
Does anyone know difference in the ride height specs between the RWD and AWD?
The gap on my '07 GS350 AWD has been killing me for years! I love the looks of the GS, but up here in the NE the AWD is the only option at the dealerships. I had to take what I could get, even though it looks like I have a lift kit. Everytime I walk to my car in a parking lot I stare at the 4x4 gap and the awful 17" OEM rims. After a couple of years it was all I could look at!
Finally, when I had my 30K service apt earlier this month they indicated it was time for new run flats. Wrong . . . It was time for a set of 20s! Just brought home the car with 20x8.5 TSW Snettertons. So much better . . . but still too much gap! I don't want to slam it, but want to be able to clinb in without needing running boards.
I like the idea of the F-Sport springs, especially if I might get a little more gap reduction coming off the AWD stilts. Let me know if anyone knows the difference between the RWD and AWD heights. Also, what's the deal with the front sitting almost ~1" higher than the rear on AWD?
Has anyone tried to test this theory with a stock OEM wheel and suspension set up (and which does not have any identified vibration issues) by loading the front end with extra weight to temporarily drop the front ride height? Seems to me this might be a good surragate to test the hypothesis that the vibrations are a result of the increased angle from the CV joints? Sort of the opposite scenario of loading up your trunk with weight.
Seems like maybe just having a couple of guys sit (carefully) over the front wheel wells might compress the suspension enough to test for vibrations. Maybe with a tape measurer you could measure the depression of the suspension with 1-2 people compressing the front end. Just a guess, but I would assume you could get a simulated 1-2 inch drop up front with 1-2 people weighting down the front end. Then your could assess teh vibrations at idol in "D" or "R".
Has anyone tried to test this theory with a stock OEM wheel and suspension set up (and which does not have any identified vibration issues) by loading the front end with extra weight to temporarily drop the front ride height?....
...Seems like maybe just having a couple of guys sit (carefully) over the front wheel wells might compress the suspension enough to test for vibrations.
