Power Steering Leak
Old Nov 1, 2009 | 10:55 PM
daddyswang's Avatar
daddyswang
Default Power Steering Leak
My power steering has been leaking for about 10 days now. I don't have the time for my car to be in the shop, so I have just been filling it up about everyday. But tonight, when I filled it up to go for a drive, the nose didn't stop and it sometimes felt like it didn't have any p/s fluid in it. When I pulled over to check, it still had plenty in it? Does anybody know what happened or am I going to have to take my car to my mechanic?
Old Nov 1, 2009 | 11:35 PM
TheMole's Avatar
TheMole
Where is it leaking from? Hose, pump, rack?
I had the same experience you did and it was leaking from the passenger side rack seal.
Old Nov 2, 2009 | 09:36 AM
Carfreak70's Avatar
Carfreak70
I got both seals leaking! WHOO HOO
Old Nov 2, 2009 | 09:49 AM
daddyswang's Avatar
daddyswang
It is leaking from the pump, I think. I can't really tell my under carriage amd engine bay is so greasy and dirty.
Did you power steering start working normal again, or did you to fix the leak?
Old Nov 2, 2009 | 10:41 AM
Mikes94GS3's Avatar
Mikes94GS3
It sounds like you need a new power steering pump, it's only gonna get worse as the weather gets colder.
Old Nov 2, 2009 | 01:28 PM
GS300 I6's Avatar
GS300 I6
https://www.clublexus.com/forums/gs-...ring-pump.html
try this
Old Nov 2, 2009 | 04:00 PM
TheMole's Avatar
TheMole
I had to replace the rack/seal since it was not holding pressure any more. The passenger side boot was already torn so you can see the fluid leaking from there every time I would top off the reservoir.
Old Nov 3, 2009 | 01:32 PM
Triple C's Avatar
Triple C
does you car push any smoke when you start it up either. if so your VCV valve would be jacked as well. Replacing isnt hard at all. I did it in mine and had never done any PS stuff before.
Old Oct 15, 2011 | 01:54 AM
afkaraoglu's Avatar
afkaraoglu
Hi, my car does the same thing as you explained. Pushes out a lot of smoke when I start it, and also I have to refill the power steering fluid every day. What is the VCV valve? How can I fix it? Can you please explain?
Old Oct 15, 2011 | 08:28 AM
ReeM's Avatar
ReeM
LMAOOOOOOOO
ajay60610
Nov 2, 2018 07:12 PM
opisdfagjo
Jul 20, 2018 06:50 AM
BUMPER
Jul 20, 2009 08:18 PM
LEXUSver
Oct 12, 2008 05:59 AM
