so you sussed these lights out? care to throw your solution/findings up here, just so in future if someone is doing a search they will find your answer
with my advice, i meant to say you should be able to get them to work since they're designed for all years, but there is a difference as you found out so it isnt just as simple as plug and play from 98-00 to 01+ :P
It was exactly plug and play, actually unplug and play lol. I just swapped around the park light and stop light clips and that was it. Worked like a charm!
Its the control arm kit, my vehicle has 57k on it so im not sure if i should just replace the bushings anyways as I am planning to keep the car for a while
