How much Money have you put in for Maint
Old Oct 27, 2009 | 06:37 PM
  #31
Thermactor's Avatar
Thermactor
Originally Posted by PureDrifter
congrats you're the first person other than myself who i've heard of even having that color
pics nao!!
Jury's still out on whether it was worth the $1,250 I spent on it. It came with a new timing belt and fan bracket, but had horrendous front seal leaks, broken A/C compressor, trashed interior, driveline vibrations and horrendous tires on it. My goal is to make it a good car for under $3,000 total. Should I make a thread out of it?
Attached Thumbnails How much Money have you put in for Maint-tn_img_6380.jpg   How much Money have you put in for Maint-tn_img_6381.jpg
Old Oct 27, 2009 | 08:18 PM
  #32
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
do it! everybody loves build threads lol.
Old Oct 27, 2009 | 09:00 PM
  #33
PK_Celsior's Avatar
PK_Celsior
Maintenance For My 95 LS400
Lexus Battery $90
ECU $900
Starter $600
Spark Plugs $60
Spark Plug Wire $130
Cap/Rotor $20
Radiator $100
Corner Assy $132 Pair
Headling Assy $500 Pair
Overflow Tank $60
Heatshield $20
Misc Parts (Clamps, Hoses, Washers, Etc) $39
Valve Cover Over Haul $190
Timing Belt Overhault $1500
Tein CS Coilover (After market but used as replacement for stock) $1500
Strut Bar/Bushings $400
About $6241 not bad probably missing some stuff. but for having it since 2002 with not a single problem. people know me as a fast driver :x. i say this lexus was built pretty tough. last thing i would need to do is my power steering pump, and probably motor mounts, tranny mounts, and diff mounts
Old Oct 27, 2009 | 10:11 PM
  #34
genetic's Avatar
genetic
I've put maybe $500 or so into it.
So far I've replaced the Starter, F&R brake pads, 4 oil filters, and a battery when I bought the car.
This car is awesome.
Old Oct 28, 2009 | 11:24 AM
  #35
omarg's Avatar
omarg
my sister's 94 is black jade pearl. Almost black. I love the color. Its only slightly green in direct light.
Old Oct 28, 2009 | 11:26 AM
  #36
omarg's Avatar
omarg
+1. i love build threads! I should really get some work done to my 90 project....
Old Oct 29, 2009 | 08:58 AM
  #37
EastWind's Avatar
EastWind
too much.
timing belt & water pump - $1000
A/C - $1000
ball joint, wheel bearing, control arms, brakes - $2000
17inch rims & tire - $1000
engine + trans mounts - $500
It could use new suspension and rear control arms.
Old Oct 29, 2009 | 10:08 AM
  #38
ZenkiFace's Avatar
ZenkiFace
Mine is a 1990, purchased last December with 151,xxx now at 164,xxx
It was well maintained by the previous two owners, but I'm a big believer in preventive maintenance as I plan to keep this car until it dies.
*All services performed by Lexus of Bellevue unless otherwise noted
1/09 Oil and filter change $30 parts (performed myself)
2/09 Power Steering flush and clean rack solenoid screen: $80
3/09 Oil and filter change $30 parts (performed myself)
4/09:
R&R leaking valve cover gasket, bank 1 $325
Transmission flush $215
Differential fluid change $79
throttle body remove & clean $310
7/09 Ignition coils $400
7/09 fuel pump R&R $1000
8/09 Oil and filter change $30 parts (performed myself)
10/09 Front brake job $200 (labor only, I provided the OEM pads)
10/09 replace wiper inserts $10
TOTAL: $2709
Maintenance cost per mile (not including fuel): $0.21
I just started hearing some clunking/creaking in the front suspension, so I'm probably up for bushings/ball joints in the next couple weeks.
Rygar470
GX - 1st Gen (2003-2009)
Jun 22, 2019 02:33 PM
NickTomsyc
Nov 1, 2017 09:55 PM
AlexISF
IS F (2008-2014)
14
Jan 12, 2013 10:31 AM
funcrusher
Lighting
Feb 25, 2011 12:44 AM
got56ry
May 23, 2008 03:36 PM
