I'm sure it looks nice at night but those lights do not match up with the housings. Doesn't seem worth it if it doesn't even come close to lining up.
that problem can be simply fixed with a custom shroud...speaking of which, are you going to put in one? mad props for having 4 projectors...I can only dream about that level of awesomeness.
man those lights came out SWEET and no thats not to much. thats perfect. almost as crisp a line as the ls430's nice job sir. u do it or someone do it for you?
That came out very sick!! But you stated that you used the LS430's in the high beam area? They look really weird to me, what happened to the bowl that is usually under the ls430 projectors?
I hadn’t planned on it. Even though I have the old gen headlights, probably the same style that he took out, I don’t really have a problem with them. At least not enough to start modding them. If someone sold the assembly as a whole that was OEM looking with say the LS460’s, I would be interested.
Wait can you explain your E46 situation? Do you have the bi-xenon feature in the high beam (inners)? Can you take shots of the lights from your engine bay for fitment?
I believe his inners are LS430 projectors that were cut down.
