What happens if I dont change my oil filter...
Old 10-22-09, 11:29 AM
lilbluu
lilbluu's Avatar
Default What happens if I dont change my oil filter...
when I am changing my oil. I drained all my oil but I tried to take off the oil filter housing but the the part i used to take off the oil filter housing broke while trying to take off the housing. I have no extra car to go buy another one so I am kind of stuck. How often are you supposed to change the oil filter btw?
Old 10-22-09, 11:31 AM
VIP > JDM
VIP > JDM's Avatar
use sand paper/grip tape, its a trick i use to remove the oil filter. you really should replace it though, oil is dirty and there should be tons of build up in it.
Old 10-22-09, 11:37 AM
SeOuLiS250
SeOuLiS250's Avatar
I think I read it somewhere that
you can keep the oil filter for 10k if you are using synthetic engine oil
(please correct me if I'm wrong )
Old 10-22-09, 11:40 AM
lilbluu
lilbluu's Avatar
I bought the car used from a dealership and I went to about 8k since the last change and this is my first oil change. I've had the car about 2 months. I am kind of at work so I dont have all the necessary tools like I do at home such as sand paper or grip paper. How hard is it supposed to be to take off the oil filter anyways? I tried really hard but I might of went the wrong way. I was pulling and pushing towards the front of the car.
Old 10-22-09, 11:58 AM
VIP > JDM
VIP > JDM's Avatar
after awhile the filter builds up pressure so its really hard to remove. i would say run the car for now, and replace that filter asap. when replacing the filter, oil will fall out so be sure to check your oil level and add oil as needed.
Old 10-22-09, 02:15 PM
lilbluu
lilbluu's Avatar
Okay, borrowed a car. I bought a second one and that broke too, again. FuUUU. Am I going the wrong way?
Old 10-22-09, 03:07 PM
Jimmy713
Jimmy713's Avatar
Pulling the handle towards the front of the car is the correct direction. I broke the filter housing removal tool too (bought from Oreilly's). I went to walmart and bought the fram oil filter wrench and bent it the first time using it. I bent it back into shape and it worked the second time around.
Old 10-22-09, 04:51 PM
XprincoX
XprincoX's Avatar
Are you using a 64mm filter wrench to remove the filter cap? It shouldn't take much effort to loosen it with a wrench... i can loosen mine with my bare hand with a latex glove on with little effort.
http://www.toolsource.com/advanced_s...toy640&x=0&y=0
Old 10-22-09, 10:49 PM
allst4r
allst4r's Avatar
got the filter tool to get it off. should be easy.
Old 10-23-09, 04:28 AM
Bichon
Super Moderator
Senior Moderator
Bichon's Avatar
The filter unscrews counter-clockwise, it's a standard thread. The last person to change your oil probably tightened it too much. The Assenmacher TOY640 that XprincoX linked is the tool I use, and it works well. Unlike the stamped metal (size F) tool that quickly bends out of shape or the plastic tools that break easily.
With 8,000 miles on your filter, I would definitely change it.
Old 10-23-09, 04:44 AM
Koz
Koz's Avatar
Contrary to what most believe the filter is safe to use for longer then the life of the oil. Not to worry, just change it ASAP.
Koz
Old 10-23-09, 05:50 AM
KrazyLexus
KrazyLexus's Avatar
You can use the filter a little longer but I personally wouldn't. You could always do the old screwdriver trick. Hammer it through the end of the filter, and turn it.
Old 10-23-09, 08:45 AM
lilbluu
lilbluu's Avatar
Okay, I had to go to a shop and take it off. They used a lift and the guy struggled with a giant wrench thingy to take it off. It was on there pretty tight. I definitely wouldnt be able to get it off in the position i was in. They did it for free since I decided to get an inspection also. Second question, since this is my first time changing my own oil, do I want the oil in between the two dots or closer to the top dot and should i check it when engine car is on or off?
Old 10-23-09, 09:04 AM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
The IS350's take 6.6 Qts with New Filter.
Which equates to approx 6 Qts. & 19 Ozs.
Joe Z..
Old 10-23-09, 10:52 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
it's the other way round....
if you have syn oil, you can keep the oil for 10K and change the filter every 5K.......
Quick Reply: What happens if I dont change my oil filter...
