Aftermarket Sound System Owners Post Your Setup!
Old Oct 17, 2009 | 06:02 PM
  #331
Pnuge88's Avatar
Pnuge88
Originally Posted by xuningshen
its really really easy, you tap 2 wires, run a power cable from the battery to the amp, and a remote/on wire from a fuse to the amp. and the AMPs for our cars are in the trunk so the only long wires u really need are the turn-on wire and power wire. as long as ur comfortable with taking your interior apart a lil bit you'll be fine. its really easy to gut out our cars.
is this remote wire just hooked up behind the navi to... what? lol what fuse? I'm going to install a sub and amp as well but i don't have ML
** dammit john always doing something lol
Old Oct 17, 2009 | 06:08 PM
  #332
nmpeter's Avatar
nmpeter
The remote wire can be any wire that turns on/off when the car turns on, such as your cigarette lighter (red wire). The remote wire is what tells when the amp to turn on and off.
I think.......
Old Oct 17, 2009 | 06:26 PM
  #333
Pnuge88's Avatar
Pnuge88
^^ interesting. makes sense. thanks for the info..
also i'm only going to run a jlw6(one) and was thinkin of getting a Rockford fosgate amp P400. the 300 is the same price as the 400. 2 channel or 4 channel? what other brands would you guys recommend. i'm noob to audio but i want quality. the amp is 200 bucks
Old Oct 20, 2009 | 07:20 PM
  #334
lowKut's Avatar
lowKut
NELOC Moderator
this is a great post keep em coming folks
btw... no kickers solo baric set-up?
Old Oct 20, 2009 | 07:28 PM
  #335
jpsilvia's Avatar
jpsilvia
you can source the remote wire from the factory amp thats in the trunk. there is a thread that shows exactly which wire to tap. but if u have a test light its easy to find.
Old Oct 20, 2009 | 07:31 PM
  #336
iSuxeL's Avatar
iSuxeL
Soon enough
Old Oct 20, 2009 | 08:05 PM
  #337
Pnuge88's Avatar
Pnuge88
thanks for the info i'll try and search for that thread
Old Nov 7, 2009 | 04:16 PM
  #338
steezy's Avatar
steezy
exactly what i said too
Old Nov 7, 2009 | 05:02 PM
  #339
IAMJAVEDG's Avatar
IAMJAVEDG
Originally Posted by iSuxeL
Soon enough
I'm waiting to see SRQ's work on your trunk so I can decide where to drive to... Orlando when I take the car to A Class for spraying, or Bradenton before spraying
Old Nov 14, 2009 | 08:03 AM
  #340
Lexasaurus's Avatar
Lexasaurus
Here is my clean & simple set-up, not too little, not too much bass.
2 ohm JL 12W3V3, Alpine MRP-500 Mono block, Custom box by Tyler Adams (Custom Enclosures Inc), install by Craig Wardwell @ Auto Sound in Willoughby, OH. I had them put a bass **** in as well.
They also quoted me $1600 for a DVD/NAV unit installed, color matched plastic and all bells and whistles, i might go for it.
Old Nov 14, 2009 | 08:38 AM
  #341
nmpeter's Avatar
nmpeter
CLEAN! Exactly how I was thinking of doing a setup. Why don't you check out the new navi system that came out.
Old Nov 14, 2009 | 10:56 AM
  #342
Lexasaurus's Avatar
Lexasaurus
Thank you! I was going for the most simple however clean looking setup, i think i nailed it
The new navi is def. something i'd love to get, but i cannot justify spending 2k on something where for $400 less, i'll have something that's capable of alot more than the new navi (although it seems that it has a ton of crazy features itself).
What do you have in mind for yours?
Old Nov 14, 2009 | 10:58 AM
  #343
TokerIS350's Avatar
TokerIS350
just picked up a JL Audio 1000/1v2 Amp & 3 JL Audio 12" W6 v2
the subs are a little big, anyone running this set up?
if so, just wondering how you guys had it set up in the trunk
and if anyone knows a good place to install this system because im completely new to this
Old Nov 14, 2009 | 11:12 AM
  #344
nmpeter's Avatar
nmpeter
DIY, it isn't hard. I have no clue about speakers but that sounds like a monstrous setup to me from what I know.
Old Nov 14, 2009 | 11:14 AM
  #345
DJKIBBLES's Avatar
DJKIBBLES
3 12w6 will take up alot of room i am not sure about how your going to run it, but my friend has 2 12 w6v2 w a jl1000 in a sealed box in an is250 and the bass is already too crazy. you cant even hear the song inside the car.
