PPE IS350 Headers
that sound gets real old quick. it sounds like something like a heat shield or something is vibrating, but its not the heat shield. I am surprised yours has that sound considering you have primary cats in them. They typically semi muffle some of that sound out.
The header coating makes them look nice.
I am still trying to figure out your dyno. I pulled 283 on a dyno jet (with borla only), and i know mustang dyno's are a bit lower, but i figured you would be up in the upper 280- lower 290 range if you added 16hp?
Your custom exhaust...do you have info on it? does your full custom exhaust have cats? what type of mufflers? x pipe? I am guessing that your exhaust probably makes up about 10 of these hp's but if your base dyno was with the full custom exhaust, then I am very wrong. Do you feel that 265 represents an average of your baseline dyno's or was that the lowest of the 3?
Do you have any pics of the high flow cats? I take it the collector joins up with these high flow cats prior to your custom exhaust but in trying to eyeball the length of your pictures here I don't see how that is possible. It's hard to see scale in a picture without something next to it like this.
congrats on your gains.
my biggest gain was the borla exhaust which was around 12hp. which is why i am curious about his exhaust.
I unfortunately never dynoed my car stock. The first dyno pull was with the F-Sport Intake and a custom exhaust with an X-Pipe and Magnaflow mufflers and stock primary CATs. The second dyno just added the headers.
I wasn't there for the dyno cause I had to work
. I will ask PPE about the dynos though and see what they say. I saw some other IS350 dynos and they were reading in the low 250 range. It would make sense that with my exhaust and intake I would read 265. Then with the headers read an overall 281 with a spike at 286. I will see if they have any more pics of the headers, if not I am sure I can get some when they start producing more sets. They ultimately cut my exhaust and removed the stock CATs and then replaced them with the high-flow CATs. I will try to get pics of this as well.
I will also be dynoing my car again on Nov. 7th when the AZ Lexus crew is doing a group dyno. It will be on a Dynojet as well so maybe those results will be more comparable to your expectations.
Let me know if this answers your questions. If not, I will try again
thanks for the info. That answers everything and makes sense.
The one item i am most surprised with is that the high flow cats that ppe used on the headers does enough of a job to keep the o2 senors happy. I'd find out if those are magnaflow high flow cats or what they are using. whatever they are using they are doing their job for sure.
You should hit upper 280's i bet on a dyno jet.
Also, I am gonna GUESSIMATE that the weight of each header with CAT attached is ~15lbs. Not positive though.
Now, why have the 250 guys been left out? and what is the likely hood of PPE manufactureing a header for us 300 guys in middle east and asia? Guess one way to find out....
