Prestigious Society Nav Overide Rx350 2010 - Anybody Tried/Installed This?
The installation guy at Cartunes has been there about 25 years and did a custom installation that I think looks great.
2) Manual Mode: There is a manual mode feature that allows total access all the time.
The price was $299. I thought it was a great deal and would reccommend it to anyone even remotely annoyed with the default limitations. I've driven the RX for about 4 hours yesterday and 4 hours today and love it. It's allready made my life much better and I feel like I've just bought another new Lexus.
Also, as far as the install goes, it requires taking apart some of the console, like for a radio install, right?
correct, install is strictly plug and play, and it involves taking the surrounding dash and console components apart, like for a radio install. imho, i would only attempt this is if you are comfortable taking your car apart and doing things like this. if not, leave it to the professionals to do (which is approx. 1 hr of labour for the install)
The most difficult part for me was removing the connectors on the back of the nav unit.
The instructions were clear and the unit works well. For now I just used the double-sided tape to fasten the control buttons to the lower dash to the right of the steering column.
I definitely like the install done for obal2400 in the picture he posted.
Tom
It I wonder if there is a way to cut the connection to the gps antenna via a switch and do this for a pennies.
I would prefer a software fix, I am a software engineer by trade and have done some hacking of hardware programming but never automotive. I'm wondering where the hard drive is and what is on it and whether it is of any use.
The nav system is so stupid, apparently some options do not put you at risk while driveing while others do. e.g. you can go to setup | audio | bluetooth | Select Mobile Player - then you cannot click on the player (last step)
The voice command sucks and it will tell you your options then even if it recognizes your response (rare) it will tell you the option is not available while in motion.
Not user friendly at all - the system must have been thrown together without any thought and with a tight deadline.
I wonder how many nav owners hate this enough to bit*h at Lexus to fix it...
if you do the wire hack or software hack, i guarantee you that your warranty on the navi unit will be voided. how do you explain to lexus the cut wires or the software changes when you bring your car in for warranty?
Since there is a hard drive you might even be able to create a backup of it to swap in in the event of a failure.
I was pretty disappointed with the instructions with their tiny b&w sketches with "property of prestigeous society" stamped on each one. He should take a lesson from Bob Randall, the guy who does Carstereoremoval.com. He provides big, real, color photos along with his detailed instructions. A few other suggestions for the directions: on p4 instead of "Remove instrument panel finish panel" and "remove lower instrument panel finish panel", saying: "remove driver side finish panel" and "remove passenger side finish panel" would've been much clearer. Also, it would've been VERY helpful to have known that the 2 left side and 2 right side radio bolts were accessible through the SAME holes. It took me forever to find the left side upper bolt! Knowing that you can see it through the same hole would've narrowed down the search area.
I agree with a previous poster who said that small hands with long fingers are helpful. (I have short fat hands so I lost out).
I did notice that Mark updated his instructions to clarify that the harness that we need to tap into IS the lower one. However, as for the grey connector, there are 2 of them. Both are to the right of the white harnesses, but the one we want is on the FAR right, not the one in the middle.
I also would've appreciated a few suggestions for [U]where[U]to attach the module. I just hope the spot I picked was a good one and that it doesn't get loose and start rattling around.
One suggestion to prevent dropping the radio bolts: use a tiny bit of sticky putty, glazing compound or even chewing gum inside the 10mm socket. I believe you can also buy a magnet that fits inside a socket. (I used trident gum
.Well, now on to the praise. THIS LITTLE ELECTRONIC BOX IS FABULOUS!!!
I finally have the full use of my Nav system back. It's great. Who in the world decided that it's "safe" to look up the artist and group for a song that's playing on XM, but it's NOT safe to look up the weather forecast or find the nearest Dunkin Donuts??? Anyway, now that doesn't matter. This little gizmo is terrific.
I have included a couple pictures of my button location. I tried a few but ended up taking my cue from "oball2400's" install. Both of my switches were used so I routed the wire through the console, brought it up through the ipod cable notch and mounted it to the right of the 2 switches.
