DIY on changing servo motors
don't try to force the arm into another position with the electric motor inside; you will snap the gears inside.
you dont have to be using it. if its stuck,frozen its gonna make the same noise. sometimes mine did it just on start up. no air on or anything
Great DIY, I started it this weekend and got far enough to see which of my servos are bad (turns out to be the driver's side and the cooling servo, but not the mode servo). I ordered all three anyway, and will get back to this after the parts come in.
A couple of comments and questions so far (please don't take these as criticism, just as a suggestion for clarification):
1) Steps 1-2 and 3-4 should be reversed, as you have to drop the access panel before you can get to the two 10mm screws of the glove box.
2) Step 8 - on my car at least, I had three nuts holding the CD player in place, not two. Both of the nuts shown in Step 8 had to be removed.
Now, for the question:
1) How did you get to the one screw on the cooling servo that is hidden behind the AC line? Did you pry on the line a bit, or had some other trick?
BTW, I ordered all three of mine online from Lexus of Pembroke Pines, which came to about $385 including shipping. That's an average of less than $130 per servo, delivered, which I think is a pretty hard price to beat.
Leon
Leon
Leon
no, i didnt pry on the line, DO NOT DO THAT. if u puncture that line u gonna be pulling the dash out. i got a short stubby type screwdriver to do this one and i agree it is a pain in the *** to take out or to even put back lol.
i would have replaced all 3 also, def IMHO the smartest idea. nice price, did they give you a discount when you ordered as my local place wanted ALMOST 175 a servo for them
funny i have NEVER seen that thread. the early pioneers lol
.Celebrating Lexus & Toyota from Around the Globe
.You got it. I couldn't figure out why I couldn't find the two screws you mentioned in step 1, then I realized I had to pull the access cover off first, which was not till step 3
.Great, I can't wait
.No, that's their regular price. I scoured the net for about two hours looking for these servos and the timing belt stuff, and these guys came out to be the lowest by far for both.
lol...i dunno the write up was long, i guess i got confused lol
try ANY HVAC supply house for a stubby screwdriver. that make some good ones, if you have a Johnstone Supply in town i can give you the exact part # to the one i used (i borrowed it off our shelf)
thats a good price.
as far as your oil pan....depends.find out where its leaking from and deal with it from there
On a similar topic, has anyone actually figured out what makes the servos noisy? The reason I ask is that after pulling the servo out, the engineer in me wanted to figure out why it was making the clicking noise. I opened up the servo and saw that the gears were all misaligned, with the big gear barely touching the driving gear. It had a lot of axial slop, so I put in a small washer (about 0.015" thick), put it back together, added four #6 screws to hold th ebody together, and the clicking stopped. So now I wonder if this is a real fix or a bandaid. It doesn't matter too much, as my order of three new servos is in the mail, but I just wonder if anyone has had any luck fixing these servos (and had longterm success)? It would sure be cheaper than the $120 per servo...
i think this is what causes them to go out is the gears jumping off but if people let them grind so long they wear the teeth down and then they are fubared. i have heard you can regrease them and i did try but i never reinstalled it after i regreased it
