How To: Build and Hardwire an Auxillary Input to OEM Stereo
Old Sep 14, 2009 | 07:09 PM
  #466
Cozmo's Avatar
Cozmo
I've read through this whole thread, and I'd love to be able to do a mod like this to use my iPod without a lame casette adapter. I understand that it wont work if the head unit wont switch to CD. I've got a 92 SC4, with the Pioneer CD player. Does anyone know if there has to be a magazine present in the CD player for the head unit to switch? The CD player appears to power on, but there was no CD magazine when I bought the car, so I dont know if its working correctly or not. Thanks.
Old Sep 28, 2009 | 12:41 PM
  #467
89MA70's Avatar
89MA70
would connectiong a Mini-to-RCA be the same and the ipod adapter? (for non iPod application)
Old Sep 28, 2009 | 01:30 PM
  #468
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
it will work, but the sound wont be as clean since you likely (on most other mp3 players) be using a preamp input
Old Sep 28, 2009 | 02:42 PM
  #469
panasonic's Avatar
panasonic
Hi does anyone have in PDF format, wiring schematic for 1997 LS400 ?
I'm looking for the speaker and subwoofer wire to install a DVD/MP3 player.
Thanks.
Old Oct 4, 2009 | 09:27 AM
  #470
LexFather
Guest
Posts: n/a
Thanks.
Please start a separate thread. THanks
Old Oct 22, 2009 | 11:52 PM
  #471
Oliverted's Avatar
Oliverted
Default I think its still too big
We made this and the day we finished it a smaller relay appeared ,so this is now MK 1 once the smaller dongle is finished I would like to install it.
Maybe using the the passenger heated switch to trigger the device I could avoid making any holes for switch ?
?How To: Build and Hardwire an Auxillary Input to OEM Stereo-dscn7697.jpg
I have a 99 with the nak I have looked but before I go chopping wires could someone confirm the pin outs for me?
Old Oct 23, 2009 | 02:21 PM
  #472
gman44116's Avatar
gman44116
Would anyone be interested for a fee to make these parts required? I have a 2000 gS300 with stock stereo no nav. I would be willing to supply all parts..
thanks for your consideration.
Old Oct 25, 2009 | 11:15 AM
  #473
blkjap's Avatar
blkjap
Originally Posted by PureDrifter
Concept:
How this works is that 4 SPDT (single pole double throw) 12v Relays are used to switch between the factory CD changer signal and external source (must be preamp) before the sound goes into the OEM amplifier.
because of this, you MUST have a somewhat working CD changer, as long as it turns on you're fine.
This SHOULD work on any lexus model that uses a CD changer that gives out a preamp. output (pretty much all iirc).
Confirmed Applications:
LS400 (all years incl. NAK** and Navi cars)
GS300/400 (98-02 incl. Nak**, ML, and Navi)
GS300 (1st gen https://www.clublexus.com/forums/sho...6&postcount=16)
SC300/400 (all years)**
**=will intercept signal between CD Changer and Headunit, not amp, needs to be done on SC300/400 (all), 98-00 GS3/4 with NAK, and 98-00 LS400 with NAK (NOT needed on non-nak 98-00 LS/GS)
Should work on:
IS300 (all years)
LX450/470 (pre 02)
SC430 (all years)
if i missed any its not because they wont work, its because i havent checked
Here is a basic overview of how the whole thing will look like, including specific instructions on wiring the trigger switch
Materials:
  1. 4x SPDT Relays @ $1.50/each = $6 (bulk)
  2. 14x crimp on (female) spade connectors @ $3.25
  3. 14x crimp on butt connectors @ $3.25
  4. 4-5ft 18awg or better Speaker wire @ $.75/ft
  5. 14-16awg wire for 12v power
  6. spst switch (i used radio shack Model: 275-634)
  7. 2x solder type Phono plugs @ $1.50/pair (4.99/4 radioshack Model: 274-319)
  8. 2x RCA female coupler @$4/pair (radioshack Model: 274-874)
  9. superglue-$1.50 (useful tip: avoid gel)
  10. 2sq. in. 2sided padded tape @ $2 (optional)
  11. Ipod dock to RCA output cable (for ipod specific install, use this because u get line-lvl (preamp) outputs )
***Since creating this tutorial Radioshack has started stocking FEMALE Phono plugs, which would mean you can save a bit of money by not having to use male plugs and female couplers. Radio shack model no. 274-337
Tools:
  1. Soldering Iron
  2. Flux
  3. Solder
  4. Wire Crimper
  5. Wire Cutters
  6. Wire Strippers
  7. Needlenose Pliers
  8. small knife/exacto knife
  9. bravery
  10. socket set (optional for install)
  11. medium size screwdrivers (philips+flathead)
Props:
Salimshah for telling me to go check my wiring again
Horta for moral support
ADDENDUM:
^flashy layouts courtesy of member rgarjr
also, let me make it clear. I AM NOT SELLING THIS.
i have materials enough for 1-2 more ppl and they have contacted me during the development phase of my little project.
If, however, there is enough demand AND the CL Admin/Moderators don't mind there is possibility to change that.
Donations are accepted to help cover the cost of development
pm me for paypal
WOW, THIS IS GREAT. I LOVE THIS SITE..... Hope I can get it right.
Old Nov 5, 2009 | 08:39 PM
  #474
tonysgs300's Avatar
tonysgs300
holy shiite thats alot of work to get an ipod working? wouldnt it be better or at least faster to buy a new cd player?
Old Nov 5, 2009 | 10:50 PM
  #475
PureDrifter
BahHumBug
CL Folding 100,000
if you think this is bad good luck getting your sub working with an aftermarket headunit using the oem amp...
Old Nov 6, 2009 | 07:46 AM
  #476
DJ420's Avatar
DJ420
Kudos. This write-up is awesome!
Old Nov 7, 2009 | 12:35 PM
  #477
mkaye's Avatar
mkaye
is it still a problem if the HU has sub outputs?
mark
Old Nov 9, 2009 | 01:18 AM
  #478
PureDrifter
BahHumBug
CL Folding 100,000
mark
only if you bypass the OEM amp and add in an amplifier for the sub separately....not worth it for the stock 8in sub.
Old Dec 9, 2009 | 05:31 AM
  #479
PureDrifter
BahHumBug
CL Folding 100,000
sorry guys, i can't give every person who asks a wiring diagram. resources are available on both this site and the rest of the internet to get your pinouts. sorry but i am a full time student and can't really keep up with all those requests.
Old Dec 13, 2009 | 05:39 PM
  #480
jimmyjay's Avatar
jimmyjay
Originally Posted by 1JDMAristo
Hey joebob1 Thanks alot im going to be doing this mod soon and thanks PureDrifter for your R&D Keep up the good work alot of people here now have music Clearer and Cleaner. you have made alot of people Happy
+1. Thanks PureDrifter for many happy miles.
