Chicago Lexus Club Chicago Representin'
Project 2009-2010 this should be fun! NSFW
Old Sep 11, 2009 | 08:51 PM
Deception's Avatar
Deception
good news!! She is alive!!
Old Sep 12, 2009 | 05:19 AM
passnu2's Avatar
passnu2
post some pics
Old Sep 12, 2009 | 01:25 PM
habeeb89's Avatar
habeeb89
Pics, sound clips, maybe even a vid.??
Old Sep 12, 2009 | 02:38 PM
Deception's Avatar
Deception
i will post pics soon guys and a vid
Old Sep 17, 2009 | 09:29 PM
Deception's Avatar
Deception
rawr!! the car is finished!! butt... the speedo and tacho dont work. my vsc light is on and no check engine light, also oil level light is and so is the washer fluid level.
anywho. im running aristo 97~ with 4spd trans and aristo ecu (uncut harness).
btw i havent driven it around yet until i get the speedo fixed. unless someone has traced the speedo wire for me and dont mind giving me some tips and pointers
thanks
Old Sep 25, 2009 | 08:07 PM
Deception's Avatar
Deception
Update. Fixed the oil level light and washer light. it was mainly on because the tachometer needed to be hooked up for the ecu in the cluster to function correctly.
if you guys out there are doing swaps please make note of this.
Here will be the info on what is done to my car. i bought a complete 97~ aristo vvti with trans and uncut harness and ecu. works like a charm. you will be looking to spend about $5000 to get the car run good. examples would be tuneup like timing, water pump, seals, and etc. another thing you would need to bolt up the propeller shaft to the car would be the 95 gs300/ls400 yoke (thats the 3 bolt looking thing). this piece only costed me 68 dollars at the junkyard. You would need a custom downpipe; at the moment I am making a custom gte vvti flange *NOTE: USDM Supra downpipes will not fit. You might also want to purchase a Speed limiter defencer, JDM motors speed limit on the motor is about 120 or so. Not Sure.
For the Harness it is a Plug and Play Harness loom, Everything will work accordingly but you lose your immoboliser and you will notice that you will also have an empty connector plug, dont worry about that for now. Once you hook up the harness and its ready for a start, you will notice your tacho and speedo is not working and so will you oil level light and washer fluid light will go on, this can be fixed by hooking up your tacho wire from the igniter (you probably will have to take the wire from the ge harness loom and re-pin it on the aristo loom) this will be hooked up the body harness. I have still yet to find the speedo wire.
The Immoboliser, you dont have to worry much. When I did research I have heard from some people that the car can not get into and Drive, or Park. I believe this is mainly the problem when you buy the Aristo Loom, when i had bought my loom I made sure that i get the orange and grey jumpers. (THIS IS HIGHLY CRITICAL) you will not be able to shift the shifter, your gauge warning lights will come on, and lastly you will not be able to go past 3000k rpm. This is a Jumper and not a Cover, I proved my mechanic wrong, LOL.
If you guys have any questions feel free to ask, I'll try my best to answer it with my knowledge. Please feel free to correct the information if I have mentioned incorrectly.
Here is the grey and orange plug. http://i611.photobucket.com/albums/t...e/IMG_0140.jpg
Old Sep 25, 2009 | 08:19 PM
Deception's Avatar
Deception
Heres the latest pics
Old Sep 26, 2009 | 05:44 AM
passnu2's Avatar
passnu2
I need a ride in this beast
Old Sep 27, 2009 | 07:54 PM
pli's Avatar
pli
brother...remove eye lids, put the bodykit on, and repaint please! your car is fuuuuuugly! and dirty.. =]
Old Sep 27, 2009 | 09:06 PM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
hey does this place have a online storefront? if so whats the site? thanks.
Old Sep 27, 2009 | 10:52 PM
darksparkz's Avatar
darksparkz
The place where we got the engine is in Toronto, at a place called Tiger Japanese, just give them a quick Google search and you'll come up with results.
Old Sep 27, 2009 | 11:12 PM
kyang91's Avatar
kyang91
wow.....this is a very interesting project.......
Old Oct 14, 2009 | 12:34 AM
kit cat's Avatar
kit cat
trace E4-5?
Old Oct 14, 2009 | 01:21 AM
Deception's Avatar
Deception
Lol thanks for the reply, this is where i am lost. it loops around
Old Nov 3, 2009 | 11:01 PM
Deception's Avatar
Deception
as promised videos.
http://www.youtube.com/watch?v=GrjhPXxUfaA
http://www.youtube.com/watch?v=8qlNhz29W7Q
http://www.youtube.com/watch?v=SCCDi7TVCjk
