Spark Plugs
Old Jul 29, 2009 | 10:24 AM
jre002's Avatar
jre002
I stand corrected. I apologize.
But like I said earlier, use OEM.
Old Jul 29, 2009 | 12:49 PM
THE.K.W.C's Avatar
THE.K.W.C
Its all good. I will use OEM spark plugs but the god damn dealer wants 44$ a plug
Old Jul 29, 2009 | 02:34 PM
EyeKutr's Avatar
EyeKutr
$44 a plug.....WTF
Old Jul 29, 2009 | 05:01 PM
THE.K.W.C's Avatar
THE.K.W.C
ya thats what i said im trying to get the model of the plugs so i can get them off ebay or something
Old Jul 29, 2009 | 05:37 PM
dlieu8989's Avatar
dlieu8989
Originally Posted by stvincent
i retract my statement. you're right.
ES uses the same plugs, yet interval is 120,000.. got me confused..
manual says Denso FK20HBR11.. can you not find one by this? last place to look for might be a dealership..
inspection i presume? i thought we had a sealed transmission that fluid can't be changed..
Drain and fill. It normally takes 3-4qts. There's cooler lines that you can possibly do a flush on; but without a dipstick...I wouldn't do it unless you've got a way to put the exact same amount of fluid in you took out. There's a fluid level check procedure that requires a cold start (under 100degrees) basically look at the flow of the fluid coming out of the level plug. IF you look at the trans pan, there's 2 plugs on it, the 14mm plug is the drain, the other one with a allen(5 or 6mm), there's a spacer in there with threads, and you're supposed to look at the flow coming out of the hole to check fluid level. Please do not attempt to take it out unless you know what the whole procedure is! Many bad things can happen if you don't have the correct level of fluid in there! Even at the dealer, a scantool is required to properly inspect the fluid level.
Old Jul 29, 2009 | 05:43 PM
dlieu8989's Avatar
dlieu8989
The plugs on the passenger side are really easy to get to. Most you have to do is take out the engine cover and intake tube. A 10mm bolt and disconnect one of the coils. Take a spark plug socket and take the plug out! It shouldn't take you longer than 5 minutes considering you've got the proper tools. Once you see the plug, u'll understand why it's $44. IT's super long and it's got 3 tips on it! Talk to the dealer and ask if you can have the plugs at list price. Some will work with you. The plugs on the driver's side will require the intake to come off.
Old Aug 25, 2009 | 06:41 PM
EyeKutr's Avatar
EyeKutr
Found plugs for $15 a piece
http://www.sewellpartsonline.com/Search.asp
Old Aug 25, 2009 | 08:33 PM
THE.K.W.C's Avatar
THE.K.W.C
thats link goes no where
Old Aug 25, 2009 | 08:54 PM
EyeKutr's Avatar
EyeKutr
you could do a search there, here I did it for you...
http://www.sewellpartsonline.com/par...id=61925&all=Y
Old Aug 26, 2009 | 09:35 AM
DCNASER's Avatar
DCNASER
will these actually work? Doesn't say what card they fit?
Old Aug 27, 2009 | 12:03 AM
THE.K.W.C's Avatar
THE.K.W.C
i was going to pm them and ask buy and can get NGK plugs that will work for 10$ i just found the part number in the lexus glove box book
Old Aug 28, 2009 | 01:09 PM
DCNASER's Avatar
DCNASER
Let me know please.
Laura
Old Mar 27, 2011 | 04:26 PM
AHughes's Avatar
AHughes
Just got on the sewell website march 27,2011 and they show the plugs for $12.95 ea. Denso #fk20hbr11
Old Mar 28, 2011 | 06:23 AM
lkapimp216's Avatar
lkapimp216
That's a great price my dealer sell them for $30 a piece, my boy let's me use his employee discount I got 6 plugs, PVC valve, and gas cap "o" ring for under $100
Old Mar 28, 2011 | 08:06 AM
twylie's Avatar
twylie
$10.66 each for the GS430 plugs from Amazon.
Denso SK20R11
