Upgrade 2001 LS430 Nav (gen 2) to Gen 4?
Old Aug 16, 2009 | 12:30 AM
bassil2022's Avatar
bassil2022
Originally Posted by LSin75075
you have to buy the actually DVD player that mounts in the trunk. they can be found on ebay for about $700-900. mine should be here in the next couple of days, so I'll post an update as soon as I have tried it.
good we are waiting your project. Please don't forget to take pictures to show us what did you do.
Good luck
Old Aug 19, 2009 | 01:44 AM
LSin75075's Avatar
LSin75075
lol, should be here by the end of the day (Wednesday). who thinks it will work?
Old Aug 19, 2009 | 02:46 PM
LSin75075's Avatar
LSin75075
k, well it's installed... but no disc (as you may have seen in the other thread I requested asking for a local to lend me a disc for a minute). but the good news is that instead of that funky old brown screen with the text behind it and a box saying incorrect disc or no disc, I have a new green screen saying to insert a correct disc... so far so good. now if only I could find a disc... if you're in the Dallas area, call me and I'll come to you 469-348-3171
Old Aug 19, 2009 | 04:00 PM
LSin75075's Avatar
LSin75075
Results are in... you tell me if it works super fast! some new features, etc...
Old Aug 19, 2009 | 04:05 PM
LSin75075's Avatar
LSin75075
oh, and the nav disc is a gen 4 v4 (old, but so what...) and the dvd player is out of an 06 Toyota Highlander Hybrid I'm so excited that it worked!
Old Aug 19, 2009 | 04:38 PM
AznRacer's Avatar
AznRacer
man im so excited now the features look just like my 06 gs300
Old Aug 19, 2009 | 05:17 PM
TJW98LS's Avatar
TJW98LS
You're talking about the DVD player for the Nav, correct? Thanks for trying this out, I'm excited.
Where did you get yours from? Is there a possibility that they have another player? If so, please PM me the info, I'd buy right away.
Old Sep 9, 2009 | 07:59 AM
sakataj's Avatar
sakataj
Originally Posted by GRAND_LS 4
I've seen this done on the GS as well. It should be the exact same connectors on the LS as well. The only issue i heard of was the background color not being memorized when changed, and will revert back to the green if i'm not mistaken (on the GS.)
So it SHOULD be a straight plug and play, especially on the LS since it uses the same screen and controls.
i can confirm the gs DOESNT revert back as i have a 2001 gs430 with the gen 4 nav upgrade
anyways just noticed this topic...guys if your looking for the gen 4 update this is the nav ecu you need.
86841-50090
here is a list of vehicles that use the gen 4 nav ecu
TOYOTA
Prius 2004 - 2005
Camry 2004 - 2006
Land Cruiser 2005 - 2006
4Runner 2005
Sienna 2005
Sequoia 2005 - 2006
Solara 2004 - 2006
Tundra 2005 - 2006
Highlander 2004 -2006
LEXUS
2006 GS300
2006 GS430
2004-2006 LS430
2004-2006 ES300/330
2005-2006 RX330
2006 RX400h
2004-2007 LX470
2005-2006 SC430
2005-2006 GX470
i went about changing mine out after my gen 2/3 fried
https://www.clublexus.com/forums/gs-...direction.html
https://www.clublexus.com/forums/rx-...-dvd-unit.html
some helpful links in there also if you'll need.
i got mine for like 400 for LKQ bought if you shop around you can find them for cheaper btw
im also gonna email these people and see if this will work with my nav headunit (btw the lexus dealership wants like 5k i think for JUST the nav ecu)
http://www.coastaletech.com/nav_kit.htm
then im gonna try and get a gx470 oem dvd/cd player and try and get a harness built for it to sit in the oem spot in my glove box so i have a oem factory dvd/cd player
ONLY DOWNFALL is once you go past the gen 4 version 5 disc the override no longer will work, hence why im trying to find out about the override bypass tool i linked to
Old Sep 9, 2009 | 01:41 PM
LSin75075's Avatar
LSin75075
keep u posted on that "Nav Kit" Definitely worth $99 to get rid of the I AGREE screen and to allow us to use the Nav while in motion
Old Sep 10, 2009 | 12:38 PM
alanchad's Avatar
alanchad
Let me see if I have this right.
On my 2001 ls430 UL the navigation system runs from the dvd and there is no hard drive. The disc must be installed to work.
On a 2004 gen 4, the disc is inserted and copied to a hard drive, and the disc can then be removed since the system operates from the hard drive?
Is this correct, or am I off in left field?
Thanks,
Alan
Old Sep 10, 2009 | 03:39 PM
LSin75075's Avatar
LSin75075
Thanks,
Alan
there's no hard drive on either model. they both just read the disc and store it in cache (RAM) while you use it. disc must always be present. there's no difference in gen 2, 3 or 4 as far as the way they work. just different software.
Old Sep 11, 2009 | 05:13 PM
LS430inDE.'s Avatar
LS430inDE.
WOW! EXCELLENT UPGRADE!!! I'M VERY IMPRESSED!
Now---for your NEXT trick, see if you can upgrade your upgrade to Gen5. I'd sooo follow your steps if it's possible!!!
Old Sep 12, 2009 | 12:19 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
i stand corrected. Thank you for correcting that bit of info.
Old Sep 24, 2009 | 09:20 AM
sakataj's Avatar
sakataj
yeah i know. would be a 100 well spent
UPDATE: never got a email back from them so i called them. spoke to a guy for bout 5 mins and he's supposed to be calling me back but who knows, guess i will have to stay on their *** about this
you can, its ALSO PNP. i didnt do it cause it was so much higher than the gen 4 units were.
no problem and welcome
Old Sep 24, 2009 | 09:04 PM
sickntired's Avatar
sickntired
I just wanted to say that I did this upgrade with my wife's RX. It is truly plug and play. Works great and seems much faster than the Gen 3. Also, the # of POIs is much higher -- has as many as the Gen 5. Can even search via phone # which I like a lot.
calamons
Aug 11, 2018 10:19 AM
Dlbama1
Jan 15, 2018 10:12 PM
Howzit
Jun 9, 2016 08:21 AM
Salil022
Aug 27, 2008 01:01 PM
lwilliams
Jan 10, 2008 12:15 PM
