Starter Clicking *OPTIONS*
Old Aug 18, 2009 | 06:40 AM
SCLexxxy's Avatar
SCLexxxy
Default Starter Clicking *OPTIONS*
SO the other day my car started doing the clicking before it started... SO I knew it was going to be the starter being bad...
So since the starter is under the intake manifold, when Itake it out I want it repaired not replaced, because I don't want to replace it with a crappy autozone unit.
So I have been told to replace the contacts on the starter, my questions is. Can I get away cleaning all the magnets or "brushes" in the start with elctric cleaner, and put new contacts on the starter and call it a day? Or Should I replace the brushes too?
I saw a thread on here where the guy got away with just putting contact on it, but this isn't an SC3 its a SC$ so I want it done right, because I don't wanna have to do the job again...
SIDENOTE: I was also thinking of dissassembling the intake manifold and buying new gaskets for it and injector o-rings and while it is apart have the intake manifold HotTanked so it is fresh when I put it back on the car.
BUT I have heard that it is a BAD idea to pull the injectors on the car, because they are brittle, and I am NOT trying to have to spend $1XX.00+ dollars for an injector or 2.
Leave Your Opinion / Experince in this department..
ThankYou
Old Aug 18, 2009 | 02:51 PM
TheMole's Avatar
TheMole
I had the clicking issues you experienced on my sc300 starter until one day all it did was click and not start. I replaced the contacts and the car has had no clicking or starting issues since then. As you stated, you have an sc400 so I personally would get an oem unit for replacement or rebuild it completely to avoid having to do it again.
Old Aug 18, 2009 | 04:27 PM
turbo7m's Avatar
turbo7m
hit it.....lol
Old Aug 18, 2009 | 05:21 PM
TheMole's Avatar
TheMole
^^That actually worked for a few weeks before it didn't work no more haha.
Old Aug 19, 2009 | 07:13 PM
IS_250's Avatar
IS_250
you're gonna have to bite the bullet. replacing the starter with an OEM one is the way to go or get yours rebuilt locally.
avoid aftermarket starters. sometimes the gear is just a little too big and causes chatter or grinding on start-up
Old Aug 21, 2009 | 11:45 AM
SCLexxxy's Avatar
SCLexxxy
Here's some pictures of everything pulled apart.. I think im gonna dissassemble the intake manifold and get it hot tanked and polish the fuel rails... IDK about the injectors tho.. I hear they are brittle..
Here's some pics.. Sorry its just my camera phone
LMK Any Thoughts
Also, I am disassembling the starter myself and replacing the contacts and cleaning the armature. And possibly replacing the brushes.
Old Aug 22, 2009 | 11:44 AM
SCLexxxy's Avatar
SCLexxxy
SO after I took out the starter and started to replace the contacts, I realized that the solenoid shaft was stuck..Looks like due to a lil water. So I cleaned up the shaft and lubed it up and it is moving very freely now...I am leaving the starter out to dry up some of the lube and stuff i used on it...
I am taking my intake manifold to the shop on monday to get hot tanked and then put it all back together...
Old Aug 24, 2009 | 05:59 PM
SCLexxxy's Avatar
SCLexxxy
OK everyone...Well I got my parts Hot Tanked today, and I was bored and stared cleaning my injectors with a tooth brush, then I decided to hit them with some polish, so I polished them up.. I Also installed new injector O-Rings for all the injectors while I was in there, and made some new vacuum hoses for the old brittle ones.. Here's some pics of the manifold going back together and everything before I finally put it back on the car .
Old Aug 24, 2009 | 06:03 PM
SCLexxxy's Avatar
SCLexxxy
BEFORE & AFTER
BEFORE
AFTER
Old Aug 24, 2009 | 07:21 PM
IS_250's Avatar
IS_250
beautiful... Were any of the plastic connectors brittle? Last time I did the coil pack on my sc4 the connectors would just crumble in my hands.
Old Aug 24, 2009 | 07:57 PM
SCLexxxy's Avatar
SCLexxxy
Yea the plastic connectors are ALWAYS brittle it sucks big time...
The injectors however were more stout than I had thought.. Figured they'd snap from being stuck in the fuel rail for a while...
Almost ready to put it back in.. Jsut gonna clean out the galley below the intake manifold and clean where the intake gasket goes..
I figured I'd do all this cause I figure it can't do anything but restrict less airflow and be better on gas...
We'll see tommorrow...
Old Aug 29, 2009 | 01:14 PM
SCLexxxy's Avatar
SCLexxxy
SO I re-installed everything, went a started it up and it starts running rough..Not sure why its running so rough.. SO then I check everything and I notice that there is some fuel leakage... So either 1 of 2 things are happening, either the injectors leaked a lil on the first prime when the fuel went into the rail and now the orings are seated and aren't leaking anymore and I have a problem with something else on the car... OR they are still leaking and that is the entire problem....
I Replaced all the O rings on the injectors and put them in on a bench, and everyone went in smooth, I even lubed them up before putting them in the rail...
The car sounds smooth when I hold the throttle at about 2,000 RPM's... But then once I let go she starts to sputter and bogg out...
I don't have anymore time to mess with it today, because I have to go to work.../
Anyone else experience any similar porblems after puttin the intake back on an SC400?
LMK Any Thoughts
Old Dec 13, 2009 | 10:38 PM
boobstar's Avatar
boobstar
what turned out to be the problem?
Old Dec 13, 2009 | 11:39 PM
HeisLegend's Avatar
HeisLegend
I just started this project as well and I DON'T plan on taking out the injectors.
Yay for pictures.
RomanTPA
Nov 18, 2010 03:46 PM
92lexus
Maintenance
Jul 23, 2008 01:23 PM
Deception
Nov 13, 2007 08:05 AM
1stREALCAR
Oct 28, 2005 10:20 AM
