Rim fitment?
Old Aug 14, 2009 | 07:55 PM
mikewho84's Avatar
mikewho84
Default Rim fitment?
I orginally bought a set of 19" Work Euroline DZ for another car that I had, but now I recently brought home a '06 GS300 AWD. Kinda wish I did my research and looked for a RWD. Anyways I'm trying to get opinions on how the offsets would look on the car. The offsets are 19x8+35 and 19x9+30, and if need be I'll add some spacers. Here is pic of actual rims. Thanks in advance.
Old Aug 14, 2009 | 10:09 PM
SNiiP3R's Avatar
SNiiP3R
The front is fine, the rear is a bit low I think. If you're not going to lower your car then it may work
Old Aug 15, 2009 | 12:12 AM
rominl's Avatar
rominl
exclusive matchup
9+30 is the same as 10+42, if you use 265 tires i think it will be ok
Old Aug 15, 2009 | 03:00 AM
mikewho84's Avatar
mikewho84
do you mean if i lower the car?
Old Aug 15, 2009 | 08:33 AM
SNiiP3R's Avatar
SNiiP3R
After reading rominl's comment, I think you should be fine either way.
Old Aug 15, 2009 | 10:41 AM
mikewho84's Avatar
mikewho84
265/35/19 should be for the rear? what about the front?
Old Aug 15, 2009 | 09:46 PM
rominl's Avatar
rominl
exclusive matchup
with 8 and 9, umm.... maybe i will do 235/35 and 265/30. a bit on the small side but the wheels are narrow so personally i try not to put 245/35 and 275/30
Old Aug 16, 2009 | 08:02 AM
enigmaos's Avatar
enigmaos
sorry for thread jacking, but I am in the same situation - 18x9 +31mm all around going on a 3G GS + stock suspension + AWD.
Based on the specs provided by rominl, they should fit with 245/40/18s? or I need 225/40 or 235/40 for front?
Old Aug 16, 2009 | 09:35 PM
rominl's Avatar
rominl
exclusive matchup
9+31 that's quite aggressive on the front, just keep that in mind
Old Aug 17, 2009 | 04:10 PM
enigmaos's Avatar
enigmaos
yeah, that's my concern. I hope they won't rub.
Old Aug 21, 2009 | 05:16 PM
mikewho84's Avatar
mikewho84
would that be a good fit? i'm trying to stretch the tires, so it'll have that aggresive look
Old Nov 4, 2009 | 06:16 PM
enigmaos's Avatar
enigmaos
245/40/18 should be fine on 9+31?
Old Nov 4, 2009 | 06:34 PM
rominl's Avatar
rominl
exclusive matchup
imho it might rub
Old Nov 4, 2009 | 06:49 PM
enigmaos's Avatar
enigmaos
Thanks. I guess it's safer to run 235/40/18s.
Nobody has this setup or similiar setup?
Old Nov 4, 2009 | 11:45 PM
memasterac's Avatar
memasterac
9 +30 is near identical to 10 +42. When you say it will be ok, meaning without any modification to the fender/wheel wale inner plastic or clips? knowing when compare to stock, a 265 tire is 10mm more & the wheel is about 28mm more to each side of the wheel/tire?
I ask because I had a 20mm spacer on the rear stock 18" wheels and 245/40 tires but it rubs a bit when hit big bumps. I downgraded to 15mm then no rub at all. My GS is slightly lowered and No fender mods.
