Premium, middle grade or regular? (merged threads)
Old Jan 19, 2006 | 12:38 PM
  #136
johhnyb's Avatar
johhnyb
I use this product in my ES and 87 works like magic if you reset the ECU. It take a few tanks but it stops the timeing from retarding and increased performance, burns cleaner and increases my gas mileage. 12oz =$12 so, 1oz/ 12gals.
www.polarmolecular.com
Old Sep 13, 2007 | 08:00 PM
  #137
king-pin's Avatar
king-pin
Default es300 uses 87 or 91 octane?
hey. does the es300 run on 87 or 91? i have an sc and i plan on getting an es300. i noticed that on my friend's es300 gas gauge it says unleaded. i need to save money on gas.
Old Sep 13, 2007 | 08:18 PM
  #138
Xterminate's Avatar
Xterminate
all lexus is recommended to run on 89 or higher octane gas I believe
Old Sep 13, 2007 | 08:34 PM
  #139
Choas's Avatar
Choas
CL Folding 10,000
I prefer the 91 octane it runs better on it.
Old Sep 13, 2007 | 08:39 PM
  #140
Xterminate's Avatar
Xterminate
if u have money sure use 91
Old Sep 13, 2007 | 08:55 PM
  #141
Pheonix's Avatar
Pheonix
Cool
depends on the year. some 87 some 89+.
they'll all run perfectly happy on 87...
Old Aug 5, 2009 | 01:49 PM
  #142
PDXLex's Avatar
PDXLex
Default Fuel Octane Rating for a 1997 ES300?!
I'm curious if it is really necessary to run premium fuel in a 1997 Lexus ES300? The owners manual states 87 Octane is adequate, but I have heard different opinions from several sources stating that the car requires 91 Octane Fuel...Is this really necessary, or am I just wasting my money on expensive gas?
Old Aug 5, 2009 | 05:13 PM
  #143
Woogie's Avatar
Woogie
89 Octane is what I use. The difference between 87 and 89 or 91 and 89 is very minimal. Let's say the difference is 10 cents and let's assume you're getting 12-14 gallons per fill-up... you're spending only an additional 1.20-1.40 per fill-up.
Old Aug 5, 2009 | 06:04 PM
  #144
ASG14's Avatar
ASG14
Only thing 91 will get you is a couple more hp. Only reason I use 93 in my car is I have to for the SuperCharger. I was using 87 before.
Old Aug 5, 2009 | 06:15 PM
  #145
Lexusfreak's Avatar
Lexusfreak
Cool
Why not try running your ES for an entire month on premium.....document your findings & do the same on regular? Let us know.
I run my 05 ES 330 on regular.....Sunoco 87......I do not get any better or worse fuel economy than running Ultra 94......and my engine purrs like a kitten.
Old Aug 5, 2009 | 07:39 PM
  #146
Bdub215's Avatar
Bdub215
the car doesnt require 91 but you wont be wasting your money on it. higher octane numbers burn slower = better
Old Aug 5, 2009 | 10:44 PM
  #147
01LEXPL's Avatar
01LEXPL
Someone on a local forum [to me] did just this. Anyways findings show:
Both fuels = same thing. The difference is negligible. Although the driving style has a lot to do with. This test was done using typical/repeating driving habits.
I run it on 87. And if it happens to be cheap i'll pour in some 91/94 a few gallons or so. I never actually ran it on a full tank of premium.
Old Aug 6, 2009 | 05:59 AM
  #148
Lexusfreak's Avatar
Lexusfreak
Cool
Yup I do the same thing when premium is cheap.
Hey 01LEXPL, where abouts in Ontario are you located? I'm quite interested in doing the LED's for my 05 ES 330.
Old Aug 6, 2009 | 08:59 AM
  #149
285exp's Avatar
285exp
I would think that the Lexus owners manual would be the definitive source, and since they say that regular is ok then disregard the other sources. I have a 1997 ES300 that I have owned since new. I have run it on both, and found no measureable difference using premium, so I now use only regular.
You will be wasting your money unless there is a noticeable increase in either power or fuel economy, and there won't be.
Old Aug 6, 2009 | 09:46 AM
  #150
01LEXPL's Avatar
01LEXPL
Nations' capital.
