ACURA says it can achieve Tier-1 status without RWD and V8s
Old Aug 1, 2009 | 10:52 AM
  #61
GSteg's Avatar
GSteg
Disadvantage in complexity and valvetrain weight? If anything, SOHC has the advantage there. Less parts and friction is an advantage to any engine.
Old Aug 1, 2009 | 01:58 PM
  #62
06TLDude's Avatar
06TLDude
For a brand that's supposedly irrelevant you guys sure do spend a lot of time talking about them.
Old Aug 1, 2009 | 02:09 PM
  #63
mmarshall's Avatar
This forum is not called CAR CHAT without reason.
Old Aug 1, 2009 | 02:37 PM
  #64
Hoovey689's Avatar
Hoovey689
2UR-GSE Owner
I think for starters, If Acura wants to be a Tier 1 player, they need to have a flagship that is more distinctive than its sibling. Both the current RL and TL seem to be stepping on each others toes. They are within 1 inch in length of each other, both offer essentially the same power/powertrain. I honestly believe the TL is the better car IMO. I think the same could be said of Infiniti's lineup. The G and M are different, but the M isn't really much of a flagship. I think they need to resurrect the Q as a former flagship. My $.02
Old Aug 1, 2009 | 02:53 PM
  #65
mmarshall's Avatar
The RL, despite a more or less similiar V6/SH-AWD powertrain, is far superior to the TL in several ways. The RL's interior is noticeably more plush (especially since the new TL interior was cheapened over its predessor). Its sheet metal, doors, and hardware, unlike the TL's, are tank-solid. Even the paint job seems to be better. And, the most obvious one.....though styling is a subjective matter, most people think the RL is not anywhwre near as ugly as the new TL.
Old Aug 1, 2009 | 03:45 PM
  #66
IS350jet's Avatar
IS350jet
Originally Posted by 1SICKLEX
Facts are bashing? Don't start flames and accuse people of bashing when they r not.
No one said the engines were bad. They r solid. They r also outmuscled and offer much less efficiency than Lexus and even Infiniti.
You also r not mentioning the 306hp engine is a 3.7 liter not a 3.5 so it's bigger but offers no more power than Lexus and less than Infiniti.
Awd hurts mpg but it should not be a cop out. The GS AWD is more efficient and a full second faster 0-60.
Now that's what I call technology and "advance".
Just for comparisons sake the ***** out 5.0 liter 416hp IS-F gets the same mpg as the 300hp 3.7 RL.
That's genius.
Just trying to point out the fact that many people here criticize (not bash, okay?) Acura for having an underwhelming engine. The fact is, it is HP competitive even without DI or DOHC's Yes, it is a 3.7 but even the 3.5 RL had 290HP nix DOHC and DI. The point is, it takes Lexus and Infiniti DI to squeeze that much HP out of their engines. Honda can do it without DI. Truly, if Acura goes DI in the TL, it will have class leading HP that Lexus or Infiniti can't touch, at least not yet.
Now only if Acura/Honda would build a decent 6 or 7 speed tranny to go along with it.
Old Aug 1, 2009 | 05:28 PM
  #67
IS-SV's Avatar
IS-SV
Sorry, I should of explained better. Yes the SOHC is cheaper and has few parts, but it also produces less power at high RPMs.
A SOHC or single overhead camshaft engine uses a single camshaft on the head to lift all the valves, whereas in a DOHC or double overhead camshaft head, two camshafts are used to lift the valves (a camshaft each for intake and exhaust valves).
A DOHC layout is better than a SOHC layout in many ways- in DOHCs, the valve timing is more precise, and better valve lift is achieved. also, a DOHC setup eliminates the need for rocker arms, hence creating better timing, and valve contact is more direct too. A SOHC layout, when tuned, can be as efficient as a DOHC, but with similar tuning, DOHCs always achieve more power than SOHCs.
We can have some of the folks with better mechanical engineering backgrounds add some additional info on the subject too.
Old Aug 1, 2009 | 05:37 PM
  #68
IS-SV's Avatar
IS-SV
Okay it's not bashing ACURA, but you've pointed out above the lack of premium car engine and drivetrain features expected in tier 1 cars, so I'll recap:
. lacking DOHC (see my post above why SOHC results in less power)
. lacking DI (and the power and fuel efficiency that goes with DI)
. lacking 6/7/8 speed auto trannys
. lacking RWD option
. lacking V8 option
. lacking tasteful styling
There is the Readers Digest version, enough of the Acura excuses.
Old Aug 1, 2009 | 05:39 PM
  #69
06TLDude's Avatar
06TLDude
I can't disagree more being 3G TL owner. The 4g TL's interior is far better than the 04-08 TL's interior. Most 3G TL owners would agree.
Old Aug 1, 2009 | 05:41 PM
  #70
IS-SV's Avatar
IS-SV
CHIT CHAT is often irrelevant, no big deal. Don't expect much meat here about Lexus cars, you will find that in the other sections (which by the way have very good model-specific information that can be very helpful to owners).
Old Aug 1, 2009 | 05:57 PM
  #71
06TLDude's Avatar
06TLDude
I understand that, but D@Mn, it's the same ole spit, the beak, no RWD, etc, etc. If you’re not in the market for an Acura why do you give a PUCK? This spit has been beaten to death. I don’t understand why the same users continue to say the same spit. Acura SUCKS, we get it. If they suck SO much why do you take time out of your life to criticize them? Just let Acura DIE.
Old Aug 1, 2009 | 06:01 PM
  #72
FKL's Avatar
FKL
The interior of the new TL sucks too. I don't see how anybody could seriously defend the hard cheap plastics they use. Doesn't feel luke a car in the same class as a 3series or A4 - just feels cheaper
Old Aug 1, 2009 | 06:11 PM
  #73
06TLDude's Avatar
06TLDude
hahahaha
Old Aug 1, 2009 | 06:19 PM
  #74
GSteg's Avatar
GSteg
If the duration valve lift and duration are the same on a SOHC and DOHC engine, it wouldn't really matter stock for stock. DOHC advantage comes in handy once you start factoring tuning and such. You can advance/retard timing one cam independent of the other. You can't do that with SOHC. But no Lexus or Acura owners (save for the TSX and such) are going to be playing around with their cam gears. SOHC is not a limitation at all, at least at these power levels.
Veyron1 made this post on team-bhp a few years ago. His post is more relevant to modifying a car. There is no tuning involved so we can't really discount SOHC when we're comparing cars stock for stock.
Old Aug 1, 2009 | 06:38 PM
  #75
IS-SV's Avatar
IS-SV
SOHC is chosen mainly for cost-saving reasons, simple enough.
Please feel free to believe what you want to. The experts know the difference especially with the precision variable valve timing systems that are used with many modern engines. Cam gears are not the issue. The direct mechanical valve actuation of DOHC is superior. The output numbers and the choice made by most premium car manufacturer to use DOHC (including Lexus, BMW, Mercedes, Porsche, Jag, etc.) speaks for itself.
