IS350 OEM wheel stud length?
Old 08-01-09, 09:21 AM
ISMAN1000
ISMAN1000's Avatar
Default IS350 OEM wheel stud length?
Does anyone know what the length is for the eom wheel stud? I need to see how much longer of a wheel stud I need to get for my spacer. Thanks...
Old 08-04-09, 11:04 PM
javyLSU
2IS OG
javyLSU's Avatar
OEM Lexus IS wheel studs are 2 inches long.
Javier
Old 08-05-09, 05:17 AM
ISMAN1000
ISMAN1000's Avatar
Javier
Thanks....
Old 08-05-09, 06:13 AM
homerjay42
homerjay42's Avatar
What size spacers are you going with?
Old 08-05-09, 03:13 PM
ISMAN1000
ISMAN1000's Avatar
I've running some iForge that has a bit of a conservative offset. I am just adding a 5MM spacer but with the spacers I can only get 2 1/2 turns on the lug. I know that Ichiba makes wheel studs for the Is350 but the longest they have is 50MM which is ~ 2". As Javier said, 2" is the stock length. Is there any other place that sells longer studs than 2"?
markdav801 (01-14-18)
Old 08-10-09, 02:23 PM
ISMAN1000
ISMAN1000's Avatar
Does anyone know if the IS300 wheels studs are the same knurl diameter (.558") as the IS350? I've found some 2.6" wheels studs for the IS300 which I hope would also work on the IS350.
Thanks..
Old 08-10-09, 10:25 PM
javyLSU
2IS OG
javyLSU's Avatar
Correction: The OEM Lexus IS wheel studs are 1.75 inches long. I was mistakenly thinking of the extended studs I bought.
Javier
Old 08-11-09, 08:31 PM
ISMAN1000
ISMAN1000's Avatar
Thanks....
Old 08-11-09, 08:34 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,842 Likes on 2,330 Posts
The stud is 12mm x 1.25mm x 36.5mm.
Old 08-16-09, 10:13 AM
Signal_jp
Signal_jp's Avatar
how hard is it to change out the oem studs to extended studs? thank you
Old 08-18-09, 08:38 AM
ISMAN1000
ISMAN1000's Avatar
Thanks....
Old 08-18-09, 09:57 PM
BoOst3d
BoOst3d's Avatar
easy. unbolt caliper, rotor, and hub and hammer out the studs.
you could use a lug with a shank like the OEM lugs instead.
gorilla makes something like this below but a spline type shank
Old 08-18-09, 10:11 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Originally Posted by Lam N 002
easy. unbolt caliper, rotor, and hub and hammer out the studs...
If you like your hubs, don't use a hammer. It will dent the ***** in the wheel bearings. Use a C-clamp with a socket and press them out. OTC makes a wheel stud press that's basically a C-clamp style tool with a forked end so the stud will clear the clamp when it's pressed out. The part number is 09650-17011. OTC also sells a full kit.
Old 10-01-09, 08:00 AM
j1b1e1
j1b1e1's Avatar
Just curious about the rear studs... Is there enough room behind to press out without removing the axle? I'd think so, but looking at this thread:
http://my.is/forums/f89/brake-pad-ro...tached-255699/
I'm worried. Anyone know? Thanks!
Whoops, wrong IS - I'm working with the IS300
Old 01-31-13, 04:27 PM
CCJ22
CCJ22's Avatar
Javier
Wait, we need to define WHAT is being measure. From the first spline to the last?
Because 36.5mm doesn't equal 1.75" as what javy's pic shows.
*Edit, I realize this is an old thread. But valuable info is in this thread.
*Edit 2... I see it is indeed measured from the first thread to the last thread.
Quick Reply: IS350 OEM wheel stud length?
