Old headlights/projectors vs New headlights comparison PICS
Just finished my retrofit and I found out one of my headlight has been replace with a newer one with the update projector.
Heres a few pics comparing the old and the new for those who are interested.
I just shined a led flashlight through the back of the projector.
old
back
****ty pic, sorry. Hard to hold everything with both hands.
You can see the narrow and uneven pattern, not a good idea to stick plug and play hids kits in these. I had them my old soarer and the glare was pretty bad.
new
Nice wide even pattern with a sharper cutoff in the new one. Should be ideal for a quality plug and play kit.
Only problem I see is the square light at the upper left hand corner. You can probably block it off.
Good idea, great writup... too bad I just took both of mine apart and redid them completely.. I used O.L.T. method, and I love them again. I will have to keep this one in mind, if theres a next time!
The new style projectors are definitely better for use with a pnp kit. All you have to do is cover up the small hole (w/ tape, thin piece pf flash aluminum, anything else that you can think of), and your good to go.
edit: nevermind, seeing things. Honestly I like the old ones.
I adjust both lights so that they overlap a little, so you dont notice that the middle part is lower.
its pretty close to a flat line on the old ones.
Also seems like they shoot more light on the corners on the ground which I like more.
in the 3rd pic 1jztts posted, ( all that uneven crap thats sits in front of the bulb) i went and cut out all of it, its been about a month now and no probs with the po pos, does anyone know if doing thats illegal?
Those squares inside the projector cause this glare above the cutoff line. My headlights are factory from 1998.
Whoa.. I have a '99 and mine look NOTHING like that. No glaring at all above the cutoff line except for the cool "rays" from the city lights. I'll have to get a pic.
