Knock Sensor may cause hesitation on SC400
So i was thinking, to anyone that has a diagnostic tool, will it tell you what the knock sensor is doing while you drive the car? OBD1 and OBD2 are different I'm sure, my 95 is obd 1, and the diagnositic port is on the intake manifold, and another is under the left side of the dash. My Snap on scanner will not hook up with toyota 1 adapter, something just doesn't quite fit correctly, the adapter is too large.
Anyone want to check this out?
One observation that I don't know is related to that topic or not is that my SC400 seems to drive stronger in really hot weather than it does in cooler weather.
My second observation, which is more related to that topic, is that with my SAFC2 I notice once in a while the knock sensor reading will spike to a value over 200 and then fall right back to zero. It's reading from knock sensor #1 too.
Now if the ecu see's a reading like 200 on the knock sensor, that whole trip the timing will most likely be retarded. I don't think an obd-1 computer is advanced enough to go back to full timing, I think it would enter a "safe-mode" It may even last longer than the whole trip.
Sometimes my car runs unbelievable well for 20 seconds after startup, and then all the sudden it feels like i lose 20hp. I know my car doesn't run as well as it used to.
Future plans are to replace the cats, change my battery cable connections and replace my grounds. Jibbby mentioned using a current/voltage regulating device which I wouldn't mind doing if the new cables and connectors don't do the trick.
But I will tell you this. I was playing around with a new snap-on scan tool. I was in the mode where you can see what all the sensors are doing real-time.
I have no exhaust on the car right now. The loudness when I rev the car (due to open headers at least) is enough to set the knock sensor off.
I've replaced the motor with a 27K mile motor. So that means 27K mile cats and 27K mile 02 sensors.
I also picked up a spare ecu to try out...
Once I get the car all buttoned back up...I'll report back with more info.
It'd be interesting to see where this goes. Keep us posted on what you find out.
