Wind Noise ES350
Old May 15, 2009 | 07:42 AM
swiftarrow's Avatar
swiftarrow
Thumbs up Got the fix done
My dealer did the wind noise fix on my 08 ES350 yesterday. He acted like he was not aware of the TSIB until I showed it to him. Anyway, it made a definite improvement, especially at higher speeds. Not the "sealed vault" silence I was hoping for, but definitely better. I wonder if the ES300 is any quieter.
Old Jul 6, 2009 | 04:55 AM
clarky86's Avatar
clarky86
Update on the tsb wind noise fix: still a little loud when driving at highway speeds. Pavement type plays a big part so I think the problem is not only leaky window trim but not sufficient sound deadening insulation on the floors and door panels.
If I get ambitious in the future, I will lay down some insulation under the carpet and in the trunk. This will keep things quiet no matter what the road surface is. This site reviews some options:
http://forums.maxima.org/audio-elect...ng-thread.html
Since the tsb only upgrades the front window gaskets, I may add some material under the back window gaskets to make a tighter seal.
For now it is good enough.
Old Jul 17, 2009 | 09:07 AM
StlGasMan's Avatar
StlGasMan
I had wind noise and I thought it was coming from the windows but they replaced the moonroof seal.
Old Jul 23, 2009 | 04:46 PM
jinnjia's Avatar
jinnjia
The TSIB provided by JimsGX is a great find !!
For some reason this paticular TSIB is still not listed or updated under many sites.
I am going to schedule the service right away, I wonder if I should remove all the tapes and foams I have intalled by myself before I visit the dealer........
Old Oct 21, 2009 | 04:03 PM
jinnjia's Avatar
jinnjia
So we finally did the this TSIB and this time I was pleasantly surprised with the result,
however I am still not 100% satisfied and wonder if anyone have done this which is found under the LS460 forum.
https://www.clublexus.com/forums/ls4...ussion-28.html
Old Oct 22, 2009 | 06:15 AM
Joeb427's Avatar
Joeb427
If you want a better ride and less road noise,buy a set of Bridgestone Turanza Serenity or Michelin Primacy MXV4 tires.Much better rated tires in every catagory than OEM Michelins or Bridgestone type from Lexus.
Old Jul 14, 2022 | 05:05 PM
bahmed's Avatar
bahmed
1st Gear
Originally Posted by JimsGX
Clarky86,
I had a new 07' RX400h that had excessive road noise and wind noise through the front side windows (in my opinion). For the road noise, I put additional undercoating on all of the wheel wells using a product called "QuietCar". The product was good, but the end result was that it didn't help much. I had Michelin MXV4's on the car and I changed them to Bridgestone Alenza's at around 18k miles. This helped somewhat, but again, didn't really resolve the issue.
For the wind noise coming through the side windows, I bought a 20' long x 1" roll of black 3M adhesive backed Velcro. I cut some long strips (around 3' long I guess) of the felt side of the velcro, about 1/4 to 5/16" wide, put the front windows down, and stuck it onto the full length of the inside rubber seal that runs horizontally along the base of the window.
This solved my wind noise problem and helped with some of the road noise problem. I think some of the road noise I was hearing was coming up through the door and past those window seals. Since its right near your left ear, it works to exacerbate the noise. I could hear the same noise on the right front passenger window as well when I was driving the vehicle. I ended up doing all four windows this way.
Then one day about a month ago, I was at the Lexus dealer having one of my other cars serviced and walked into the showroom to take a look at the redesigned 2010 RX350 that was on the showroom floor. As I was sitting in the drivers seat, the window was all the way down and I took a look at the lower inside window seal. It had the same Velcro type felt on the inside of the rubber window seal!
Jim
hi jim
​​can you please explain me which rubber was that, i have the same. problem wind noise and road noise and i think this was the similar issue.
rvgraham
Feb 21, 2018 06:05 PM
leonrojo18
May 1, 2017 04:55 PM
RRocket
Mar 30, 2017 08:36 PM
alexlude
Nov 4, 2016 02:39 PM
skabei
NX - 1st Gen (2015-2021)
Aug 10, 2016 11:58 AM
