Rx330 Brake Pads replacement
Old 01-14-08, 08:57 AM
mandyfig
Forum Moderator
mandyfig's Avatar
Default Rx330 Brake Pads replacement
I did my brake pads, front and rear (@ 31,000 miles) and it is pretty straighforward.
I bought the OEM pads from Sewell Lexus. I had the Rotors turned at the Dealer.
I took some pics and probably can write it up a a simple DIY. If there is some interest, I will.
Old 01-14-08, 02:09 PM
Grumpa72
Grumpa72's Avatar
I would like to see a write up and photos.
Btw, why did you turn the rotors? Were they warped or extremely grooved or did they sell you on the idea that they need to be turned with each set of pads?
Gary
Old 01-14-08, 02:41 PM
mandyfig
Forum Moderator
mandyfig's Avatar
They were "warped" according to the dealer (I complained about vibration). Here's the catch...they would not replace the pads since they were below 3 mm thick (which they were not..I measured them).
They wanted to charge me for the warranty work.... But since I had the pads already bought, I did it myself and the advisor had the FRONT rotors turned according to the Report (but actually had the rears turned, too).
So go figure.
Old 01-14-08, 02:44 PM
mandyfig
Forum Moderator
mandyfig's Avatar
Default Brake Pad replacement
Bought the Front and Rear pads, OEM, Toyota. ~ $95.00.
Old 01-14-08, 02:45 PM
mandyfig
Forum Moderator
mandyfig's Avatar
Default Front Brake
Here's the Front prior to dis-assembly:
Attached Thumbnails Rx330 Brake Pads replacement-rx330-front-brake-medium-.jpg
Old 01-14-08, 02:47 PM
mandyfig
Forum Moderator
mandyfig's Avatar
Remove bottom slide pin, swing up and tie caliper.
Old 01-14-08, 02:49 PM
mandyfig
Forum Moderator
mandyfig's Avatar
Remove old pads, transfer anti-squeel shims and wear indicator. Put grease in between shims.
Old 01-14-08, 02:51 PM
mandyfig
Forum Moderator
mandyfig's Avatar
Install new pads. Use a mirror to help you snap in the pad on the back side of the rotor.
Old 01-14-08, 02:52 PM
mandyfig
Forum Moderator
mandyfig's Avatar
Installed new pads. Ready to bolt caliper.
Old 01-14-08, 02:53 PM
mandyfig
Forum Moderator
mandyfig's Avatar
Assembled with new Front pads!
Attached Thumbnails Rx330 Brake Pads replacement-assembled-front-medium-.jpg
Old 01-14-08, 02:55 PM
mandyfig
Forum Moderator
mandyfig's Avatar
I will do the rears tomorrow! Good luck with the DIY'ers! I did not get a chance to clean up the calipers, etc.. But will tear them down again soon. For the grease, I had left over grease from a Honda caliper kit, that's what I used. I have to find out exactly what Lexus uses for the GREASE as specified by the manual. Anybody?
Old 01-14-08, 03:29 PM
Lex2000TL
Lex2000TL's Avatar
Did you have to push piston in brake cylinder in with special tool, or your caliper fit right over. Usually new pads are thicker than the old ones, so you have to push piston in for clearance.
Old 01-14-08, 05:17 PM
mandyfig
Forum Moderator
mandyfig's Avatar
I used a C Clamp. Before you start, you will need to suck out some brake fluid for it not to spill over. I used a baster. Be very careful in hnadling brake fluid. It will damage the paint. Do it carefully. Be sure to fill it back up to the max line with fresh fluid after you are all done.
Old 01-14-08, 06:25 PM
Grumpa72
Grumpa72's Avatar
Great photos. Thank you. I suspected that these calipers pivoted on the upper caliper bolt since my Acura did the same thing. Why did it take the Japanese engineers to figure out that technique whereby the bottom bolt gets removed, you pivot on the upper and swap out your pads. Btw, in the other brake jobs I have done, I have usually not needed to extract excess brake fluid, as long as I have not added fluid between changes. I will copy the photos and archive them on my computer.
Thanks again,
Gary
Old 01-14-08, 09:42 PM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,105 Likes on 994 Posts
You don't want the reservoir to overflow in the engine bay. Brake fluid will eat the paint. If you dont have a baster, use a clean bottle cap to scoop out fluid.
I have found the flavor injector (looks like a hypodermic needle for horses) ...left over from fried turkey (from thanksgiving) a very useful tool.
Salim
Quick Reply: Rx330 Brake Pads replacement
