Quote:
Originally Posted by K-Bud
Was this your way of saying RTFM?
But since this is not the usual case of someone that is to lazy to look themselves and since you are a fellow Marylander let me summarize...
Replace engine oil and oil filter
Lubricate front drive shaft bushings
Measure brake pad thickness and rotor runout
Replace active height control system fluid
Replace brake fluid
Replace engine filter
Replace transmission fluid
Re-torque drive shaft flange bolts
Rotate tires
Inspect nuts and bolts on chasis
Lubricate propeller shaft retorque bolts
Repack front wheel bearings
Repalce air conditioner filter
Replace differential oil
Repalce tansfer case oil
Road-test
Various items that also require inspection
Ball joints and dust covers
Body
Brake lines and hoses
Charcoal canister
Differential oil
Drive belts
Drive shaft boots
Engine coolant
Engine valve clearance
Exhaust
Fuel lines and connections, fuel tank band, and fuel tank vapor vent system hoses
Fuel tank cap gasket
Rack and pinion assembly
Steering linkage and boots
Transfer case oil
Transmission fluid
