View Single Post
Old 06-28-09, 04:17 PM   #2
shern
Trader Score: (2)
shern's Avatar
Send a message via MSN to shern Send a message via Yahoo to shern
Mk3 propeller half-shaft vs. SC300 half-shaft. The Mk3 is the chode and a hair shorter.
W58 vs. R154
Here you can see the differences between the two transmissions. The R154 with the Soarer extension places the shifter in the exact location as the W58. The hole should line up exactly.
W58 pulled on that magical Harbor Freight Transmission Jack
W58 vs. R154
W58 shifter
R154 Soarer shifter extension
New Rear Main Seal and Pilot Bearing
New JZ-R154 flywheel with new OEM flywheel bolts (loctite'd and sealed)
__________________
_______________________________________________
Shern's W58 to R154 swap thread
shern is offline   Reply With Quote
