Key Programming 2002 LS430
Lots of info in this thread. I just finished programming my replacement key.
1. Bought it on-line from Remote Supermarket, about 60 bucks.
2. Got the key cut by a local locksmith shop that does auto keys. Cost less than 20 bucks.
3. Followed the instructions provided by the vendor, after a couple failed attempts, finally got it to lock and unlock the doors, but would not allow the car to start.
4. A second set of instructions from the vendor, explained the transponder programmng. That worked, now the key is fully programmed and I am pleased.
Adding remote key functions (worked first time):
driver door open, other doors closed, no key in ignition
insert and remove key in ignition twice (without turning it on)
close and open drivers side door twice
insert and remove key from ignition
insert key in ignition
close all doors
turn ignition to on then off
remove key
press lock and unlock on the key at the same time
press lock on the key
open door
wait 40 seconds
procedure to program transponder (took 2-3 tries):
1. Make sure all doors and windows are closed.
2. Insert Master key into the ignition cylinder.
3. Cycle the ignition cylinder from On to OFF five times.
4. Open and close the driver side door 6 times.
5. Remove the Master Key and insert the new duplicate key.
6. The new key will be registered after 60 seconds. The THEFT light on the dashboard will go out, indicating that programming has been completed.
Is this just how thing's work, or did they do something wrong? Maybe the key is screwed up?
key shipped was $60
key cutting was $40
first try success priceless.
Could anyone post a pic of a transponder versus a pic of a remote?
Could I buy a used key off ebay ($20-30) and get it to work? They say the keys are already cut, so does that make them useless for us?
I have one key that looks really, really old but works fine to crank the LS with the key in my pocket but we only got one and no remote thingy like other Toyotas have. Will an ebay key work?
I have 2001 LS430 for Europe, and only 1 key like a fish :-) In manual named "Smart key". The car can recognize me - the lights on mirrows turns on and in a few seconds the doors opens. But function "Keyless go" does not work, I cannot turn the ignition without inserted key. What is wrong and how to make it work? Thank you.
Lexus LS 430
Program transponder:
Note: Steps 3 and 4 were done very quickly( ie. 15 seconds). Slower did not work after numerous attempts.
Programming Remote:
1.Driver door open, other doors closed, no key in ignition
2. Insert and remove key in ignition twice (without turning it on)
3. Close and open drivers side door twice
4. Insert and remove key from ignition
5. Close and open drivers side door twice
6. Insert key in ignition and close driver’s door
7. Turn ignition to on then off(once)
8. Remove key. The locks will cycle once
9. Within 1 second after locks cycle - Press lock and unlock on the key at the same time for 2 seconds.
10. W/in 1.5 seconds press lock on the key for one second.
11. To stop programming- Open and close drivers door. Put key in ignition and pull out.
Lexus LS 430
Programming Remote:
Thank you,
dB
Code was HYQ12BBK
I was originally concerned upon seperating the transponder portion that the interior #s did not match exactly. Tried twice with no success & replaced the battery CR1616 and then the 3rd time with the method below was a charm!
Transponder Procedure:
5. Remove the Master Key and insert the new duplicate key (Turn to ON!).
6. The new key will be registered after 60 seconds. The blinking THEFT light on the dashboard will go out, indicating that programming has been completed.
Now to program button functions. Must say this process seems very un-Japanese!!
Lexus LS 430
Programming Remote:
Need an advice. I just got an 04 LS430. Bought a new key. Was able to cut it, program it to open and close doors, but cannot get it to work to turn on the engine. Security keeps blinking. I have followed about instructions at least 20 times without success.
Any tips anyone can share? Maybe 04 had a different procedures?
