Stock Sub working w/ aftermarket hu
1. Do the RCA mod
2. Bypass sub amp (picture below)
3. ?
4. profit
Im thinking of splicing these wires together on the sub amp harness:
1 -> 10
5 -> 9
Any thoughts/ideas before I do this?
I really have not had a chance to try it as of yet............no time lol
92 SC400 stock Pioneer, did a 7120 Kenwood +Ipod+GPS to factory amp and speakers. Goddamn thing has a constant buzz that can be heard at lower volumes- it's not alternator since the damn car wasn't running.
Start the car and the whine is unbearable. I used the Metra harness as it was supposed to be wired and phono plugged the sub harness (black to center pin RCA white to RCA - )
using the ground on the metra harness didn't even supply a clean enough ground to fire up the radio. I got huge buzz, and 1st thing I did was disconnect the antenna. Deck drops dead. So, I created a new ground using a bolt by the ABS computer. Deck now turned on without RCAS or Antenna plugged so I thought we were golden.
Plugged it all in and freking noise again. Start the car and alternator whine on top of buzz.
I believe the buzz is somewhere in the factory amp. The buzz is prevalent whenever the factory amp is turned on, it's not the CD drive and it's present through IPOD or any source.
So,
1)- Metra supplied ground on harness annd therefore the factory ground wire is worthless.
2)- left As-is it doesn't seem to work as advertised. The buzz like I said, is present car not running, and it's a constant tone regardless of source or input on the radio so it can't be something inside the stereo being amplified (hard drive noise on IPOD for instance)
3)Unplugging all RCA's will eliminate all buzz, plugging in sub only did NOT buzz
I gave up, just returned the damn car to stock until I'm ready to totally remove everything and go aftermarket all the way. This is way too much Bull***** just to get IPOD. This particular car has fought me tooth and nail on ANYTHING I've done. Lower it, and I get coil rattle, numerous bodywork repair problems thanks to PO. This car is a POS to modify, sorry.
I'm not a stereo rookie, used to be an installer and MECP certified. I'm just sick and tired of everything being a pain on this car.
rjp
A little over 50FT of speaker wire later, everything works as it should. Deck power sounds identical to the factory pioneer amp, literally sounds the same.
I was in a rush to get to a bday party so I left the factory amp plugged in and powered up - literally the only wires cut were the output wires to the speakers. I didn't have time to experiment to see what happens if I remove the stock amp all together. It seems that the remote on (for the sub amp and power ant controls) are all daisychained through the amp.
Behind the dash, I have the Metra wiring harness adaptor wired up as it should be except no RCA input, 4 sets of speakers going to the back of the car supplying signal to the factory speaker wiring, and a "Phono Jack" spliced into the subwoofer input leads on the car and plugged into the sub out on my HU.
Like I said, works like a champ. Literally the only thing missing is the changer I left out.
In a few months when budget permits 4x 6.5" seperates, and a freeair 10" in factory location with one hell of a multichannel amp running it all will finish this deal up.
I just helped a buddy install an Alpine HU into his SC with the Metra harness. I have EXACTLY the same issue you describe. As soon as you power up the radio, there is a buzz, even when the car is not running. And then alternator whine. Pull the RCAs and it's gone.
I suspect some sort of ground loop between the HU and the factory amp. I noticed that the signal grounds and the chassis ground are connected. I'm a bit stumped. If somebody has some insight, please chime in.
Used to work on other cars (like OEM BMW) that way.
It's not worth screwing with, bypass the amp. It's $11 in speaker wire and the quickest answer. You'll spend all day fooling with changing grounds, etc etc total waste of a day, plus you aren't risking burning up your HU outputs. The harness in the trunk is even long enough you can stand outside and cut it. Pretty sweet.
I'm sure someone out there will insist removing the factory amp and running all this wire is the answer but this is the fastest, neatest and is the least amount of butchery to get it to work. I can return my car to full stock in under 30 minutes if I need to.
rjp
Do I need to bypass the factory amp to get rid of the whine?
Use some ground loop isolators on the RCA plugs to get rid of the alternator whine. I had to do this.
Make sure you tap into the correct pins at the harness for the factory sub. I have a picture further down on the first page. The sub amp is already powered by the speaker amp from the factory. All you need to do is tap into the correct Sub in + and - wires and splice them to your hu's sub out.
