2000 RX300 rattling noise
Old 05-25-09, 12:48 PM
ofussalva
ofussalva's Avatar
Default 2000 RX300 rattling noise
i have a 2000, RX300 AWD & i just recently noticed a rattling noise from under the drivers side when i stop at a light, stop sign, etc... "Almost sounds like pebbles in a can"
but when i shift to park the noise stops. Anybody ever had this problem???? need help
Old 05-25-09, 03:42 PM
code58
code58's Avatar
It may well be your catalytic converter coming apart inside. Does it still do it when you put it in neutral? If it only does it in gear, have someone get in the car, firmly apply the emergency brake and FIRMLY hold the foot brake with their left foot and slightly adjust the throttle with their right foot, if necessary, to create the noise. Lay on the ground along side of the car and hold a yard stick to the CC and to your ear. You should be able to hear the amplified sound if that is the problem.
Old 05-25-09, 04:48 PM
salimshah
salimshah's Avatar
With a helper inside or outside, try to locate the source.
Salim
blazer99
05-27-17 09:52 AM
jay33
02-04-14 07:43 PM
cardalums
08-14-07 09:43 AM
lexusownr2
03-10-04 04:28 AM
p1fcl01
04-24-03 01:50 PM
Quick Reply: 2000 RX300 rattling noise
