GTE swap rebuild thread into SC300
Old May 4, 2009 | 09:28 AM
  #76
slappy96's Avatar
slappy96
Default I almost can't contain my anger...
Pretty frustrating setback this weekend.....
The JIC Magic (LEXUS OEM wheel manufacturer by the way) wheels that I've had for a year don't clear TT brakes in the front. 18" and were specifically advertised on Carson Toyota's site as clearing TT brakes. I have the JForce 07 wheels. Frustrating beyond belief
It's laterally about 1mm/ not vertically.
Options:
1. Grind on caliper
2. Small wheel spacer
3. New wheels (not likely)
4. New brakes (not likely)
Old May 4, 2009 | 10:04 AM
  #77
tonysc400's Avatar
tonysc400
i did the same swap but with my sc400..and i am using my stock sc400 rear end..would the sc300 rear end be better?
Old May 4, 2009 | 10:16 AM
  #78
slappy96's Avatar
slappy96
I'm definately no expert in rear ends..........anyway
It probably depends on the gearing you want. I'm pretty sure my setup will be the worst possible, so at least you'll be a little better than me. No LSD FTL
SC300 Auto = 4.27
SC400 = 4.07ish ??
Old May 4, 2009 | 02:35 PM
  #79
RX7 RAGE's Avatar
RX7 RAGE
Options:
1. Grind on caliper
I'd do option 2.
Old May 10, 2009 | 09:05 PM
  #80
slappy96's Avatar
slappy96
Originally Posted by RX7 RAGE
I'd do option 2.
Option 2 en-route...
3mm spacers going on the front
Old May 10, 2009 | 09:16 PM
  #81
slappy96's Avatar
slappy96
Default Update: Turbos/Piping and timing belt on
Cam gear test fit
cam gear closeup
Coil packs in
Top shot
New PCV
Old May 10, 2009 | 09:21 PM
  #82
slappy96's Avatar
slappy96
Default Turbos and stuff
no 1 and 2 compressors on
12 blade closeup no.2 turbo
2nd shot of no.2 turbo
band clamps on
wide shot of turbo assembly
Old May 10, 2009 | 09:22 PM
  #83
RX7 RAGE's Avatar
RX7 RAGE
Wow, that's so clean.
Old May 10, 2009 | 09:32 PM
  #84
slappy96's Avatar
slappy96
front shot...funny looking
Bottom of turbo-you can see the bearing
engine rear shot
chrome is cool
timing belt on
timing belt tensioner
timing belt closeup
TDC
Old May 10, 2009 | 09:33 PM
  #85
slappy96's Avatar
slappy96
Heat shield on
Black piping
Black piping front
Old May 10, 2009 | 09:38 PM
  #86
soarer13oy's Avatar
soarer13oy
so beautiful......
Old May 11, 2009 | 12:43 PM
  #87
LMAOMAO's Avatar
LMAOMAO
wow. thats ridiculous
Old May 11, 2009 | 12:51 PM
  #88
ICONYQ's Avatar
ICONYQ
nice very nice...ty for the shot on the black piping. I had planned on doing that and wondering how it woudl look. What paint did you use? I am going to do the intake as well.
Old May 11, 2009 | 01:18 PM
  #89
slappy96's Avatar
slappy96
Originally Posted by soarer13oy
so beautiful......
Thanks for the inputs.
I just used semi-gloss dupli-color engine enamel. I don't imagine it will last that long, but it wasn't hard either. I cleaned all the pieces with brake disc cleaner pretty thoroughly.
Old May 11, 2009 | 01:19 PM
  #90
codetoad's Avatar
codetoad
Looks great man, keep up the good work.
Giving me some motivation to get my 1JZ rebuild finished
Mine won't be as clean as this one when I'm done, but hopefully she'll run
