B-ver's Build Thread
Old Apr 26, 2009 | 10:03 AM
  #241
camberSC's Avatar
camberSC
Sick Built! When can I go check it out in person?
Old Apr 26, 2009 | 01:31 PM
  #242
SoarerAZ's Avatar
SoarerAZ
Continuously following the thread, loving the progress.
Old Apr 27, 2009 | 08:50 PM
  #243
BattleVer's Avatar
BattleVer
Did a few things. Got the head back, then started on shimming the valves. Ordered a bunch of shims from toyota so hopefully get those soon. The valve lash is pretty much the only thing keeping me from putting the motor together and sticking it in the car.
Then finished up the brake lines and did the clutch line.
Got bored since I'm waiting for parts, so started on the electrical again. Think I'm going to throw away the original switch panel and made one on the dash cause it looked too empty. Used some thick carbon fiber sheet and cut it out to fit the little area in the middle.
O yeah, thats the steering wheel off my ae86, it fit the sc. Just going to leave it on there till I find a replacement since it looks better then the stock one. Started on the main circuit board. Thinking of running it behind the switch panel basicly on the firewall pretty much. That way the wires are rather hidden. Not sure if I like it yet. May redo it like alot of things I end up with.
Old Apr 29, 2009 | 09:04 PM
  #244
BattleVer's Avatar
BattleVer
Need to update with some new sponsors. Some of you remember House of Kolor, they sponsored the paint. Competition Clutch is on board with help on a twin disk setup. Also Bullseye Power Turbos is helping with S368R turbo.
Last couple days where spent working on product. The biggest thing holding me back right now is money. Even when the car is done, its going to take money to run it at events. So I spent some time trying to make some extra funds and worked on some products. You mkiii guys will be happy, 150 end brackets...
I need to sell these seats to get my money back. Sparco Fighters, used as back seats in a honda Fit for sema last year. They are bottom mount seats. I can take more pics if need be. Rather have local pick up but I can ship if need be. Rather sell as a pair also at $600 (shipping not included). No brackets or rails.
Old Apr 30, 2009 | 07:04 AM
  #245
rwdanthony's Avatar
rwdanthony
mkiii related:
whats the end brakets for?
also what happened to those battle version tie rods for the rear suspension?
Old Apr 30, 2009 | 07:12 AM
  #246
BattleVer's Avatar
BattleVer
They are the end brackets for the mkiii rear camber links and rear traction links.
You mean the rear links I have on my car? They have always been available.
Old Apr 30, 2009 | 09:23 PM
  #247
BattleVer's Avatar
BattleVer
Clutch came in today. Competition Clutch really came threw. When they said it was a complete kit, they were right, this has to be the most complete clutch setup I've seen. Came with everything including a slave and clutch line. Converts from pull to push style, twin disk, light flywheel. I weighed it earlier and think it was 23lbs with the flywheel and clutch together. Best part is its a tight diameter clutch so it drops down the rotating mass of it. Should make the motor perky.
Also picked up the shims for the head and got to work on that for a few hours. Pretty happy now that the head and the rest of the parts are ready to go together. Just need to line up the DVD filming and should be in the car soon. I did finally find a spot to stick the damn kill switch.
Old Apr 30, 2009 | 10:44 PM
  #248
TougeSC3's Avatar
TougeSC3
Alex, are you still using the W58 or the V160?
Old May 1, 2009 | 12:38 AM
  #249
BattleVer's Avatar
BattleVer
Im using the r154. Couldnt find a v trans cheep enough.
Old May 1, 2009 | 07:20 PM
  #250
HeisLegend's Avatar
HeisLegend
Alex, lend me some money bro.
I have tons of pens and papers and you know what that means.
IOU's buddy....that's right, take it allllll iiinnnn. hahahaha.
I feel like a kid watching the presents under a christmas tree as the day draws nearer to the completion of this beast.
Old May 1, 2009 | 10:32 PM
  #251
BattleVer's Avatar
BattleVer
Dropped off the clutch at Speed O Motive to get ballanced. Figured since the crank was ballanced, needed to make sure the flywheel and clutch was too. Come to find out it was good so no worries there. Moved the switches to the center dash peice. They look alot better, just hope I can reach them. Mounted the ViPEC V88 (ecu) in the center of the trans tunnel. Should be easier to wire up from there.
Anyone got a stock guage cluster? I need to mount the guages and dont feel like having to create something to fill that hole. Seats still for sale. Only a few things left to find, some 1000cc injectors are the main things I need right now.
Old May 3, 2009 | 07:46 PM
  #252
WICKED 1's Avatar
WICKED 1
i have a stock cluster and can ship it on monday. pm me
Old May 4, 2009 | 07:07 AM
  #253
96SC4's Avatar
96SC4
WOW! baller! keep up the good work....
Old May 4, 2009 | 08:25 AM
  #254
TheRonTom3's Avatar
TheRonTom3
That clutch looks like SRS BZNS
Old May 4, 2009 | 09:59 AM
  #255
plex's Avatar
plex
1UZFE/2JZGTE
Wow.............. subscribed.....
