LS460 Wind Noise Fix (continued discussion)
The dealer fixed it with no problem, but that's such a skinny little seal that it looks fragile to me.
Mike
I will let the dealer know about this.
This one is a 2007 LS460 VIN JTHBL46F475038619.
http://www.vehix.com/inventory/detai...770000013EBDD2
If you don't want to chase the link, here is part of what it said:
Quote:
Manufacturer buyback for wind noise. The vehicle carries the remainder of factory warranty. What is Manufacturer buyback? When the vehicle goes back to the dealership for the same problem more than twice. The manufacturer has to buy back the vehicle from the customer and fix the problem before reselling the vehicle. The advantage: you save thousands compared to the going price on a similar LS460 and you get the same manufacturer warranty and the problem is fixed. By law because it is a buyback the vehicle will have a branded title.
End Quote
The latest wind noise buyback tally, including this one, looks like this:
#1 JTHBL46F775045743 2007 LS460 OH
#2 JTHGL46F875003331 2007 LS460L FL
#3 JTHGL46F175008967 2007 LS460L OH
#4 JTHGL46F975002186 2007 LS460L PA
#5 JTHBL46F875008216 2007 LS460 AZ?
#6 JTHGL46F475017758 2007 LS460L FL
#7 JTHGL46F175009066 2007 LS460L FL
#8 JTHGL46F575004856 2007 LS460L FL
#9 JTHGL46F875018220 2007 LS460L FL
#10 JTHGL46F075016218 2007 LS460L LA?
#11 JTHBL46F585065636 2008 LS460 CA
#12 JTHBL46F875048814 2007 LS460 FL
#13 JTHBL46F075008162 2007 LS460 FL
#14 JTHBL46F275022984 2007 LS460 FL
#15 JTHGL46F575012777 2007 LS460L AR?
#16 JTHBL46F575021960 2007 LS460 FL
#17 JTHBL46F475038619 2007 LS460 FL
This one is a 2007 LS460L VIN JTHGL46F675014215.
http://cgi.ebay.com/ebaymotors/Lexus...t_29595wt_1401
Quote:
This car is a Lexus Buyback Title vehicle that we purchase from the Lexus Factory Sale. It was re-purchased because of the customer complaining about wind noise. Lexus has performed the necessary repairs and replaced the necessary parts to fix this car and it is in Like-New condition! It is still under the original factory warranty and the entire car is still covered by the original Lexus warranty! This car originally listed for $85,232.00!
End Quote
#18 JTHGL46F675014215 2007 LS460L FL
This one is a 2007 LS460 VIN JTHBL46F675013656.
http://cgi.ebay.com/ebaymotors/Cars-...t_32109wt_1401
Quote:
This is a Lexus Buyback Title vehicle that was re-purchased by Lexus because of wind noise. Lexus replaced the door insulation, and the left & right drip moldings to repair the problem, and it is completely covered by the remainder of the factory warranty which is bumper to bumper until 12/28/2010 or 50K miles, whichever occurs first! Additionally, the powertrain warranty is good until 12/28/2012 or 70K miles, whichever occurs first! Therefore, you have TOTAL peace of mind about buying this vehicle and saving thousands of dollars!
End Quote
#19 JTHBL46F675013656 2007 LS460 ?
I was experiencing a mild wind noise problem. I heard three sounds 1) the sound like the door or a window wasn't fully sealed 2) wind rushing past the window and 3) wind catching the front of the window molding (mostly in cross winds).
The fix pretty much eliminated #1 and reduced #2 and #3 by about 25%. Now, 25% doesn't sound like much, but it took it from being a distraction to being what one would have expected all along.
Joey B.
This one is a 2007 LS460 VIN JTHBL46F975037417.
http://www.vehix.com/inventory/detai...770000012E70C8
Quote:
Manufacturer buyback for wind noise. The vehicle carries the remainder of factory warranty. What is Manufacturer buyback? When the vehicle goes back to the dealership for the same problem more than twice. The manufacturer has to buy back the vehicle from the customer and fix the problem before reselling the vehicle. The advantage: you save thousands compared to the going price on a similar LS460 and you will get the same manufacturer warranty and the problems are fixed. By law because it is a buyback the car will have a branded title.
End Quote
#20 JTHBL46F975037417 2007 LS460 FL
this wind noise make me craaaaaaaaaaaaaaaaazzzzzzzzzzyyyyyyyyyyyyy. especially worse on windy days
It sounds like you have buyers remorse now and just want to get rid of the car. If this fix was available when I had issues with my first car, I would still be driving it.
I tried covering the triangular piece with masking tape too and no help.
I then did Jeff's fix and it worked completely. This leads me to believe the wind is coming through a passage between the outer door skin (including the outer triangular piece) and inner triangular surface with all the holes and seam gaps.
Aren't you the same one that wanted someone to go over to a Merc dealer in the Wheatridge, CO area and checkout an LS460 for you? I offered twice and you never responded.
Then you were trying to pedal some 'gold' badging. I asked if it was the OEM badging or just the cheap electro-plated jobs the gypsys were doing...again no anser.
Then there were a couple other issue since then, you seem to have a lot of issues like this.
Whit
i just want to get this fixed so i can not feel like an *** driving this amazing car and hear crazy wind noises in my ear the whole time. i don't want to have to drive with blasting music to cover it up.
i will do the jmcraney fix for sure. i was just covering the entire piece with tape to see if it makes it go away. it doesn't help reduce it but i still hear annoying wind noise. so it makes me feel there are other spots the wind comes in from.
i must not have gotten your messages when you offered to go see them. also for the gold badges which were pretty nice. i ended up trying to polish them off but didn't look so nice, so i just bought all new chrome pieces and just installed them and it looks sweet! even the long trim piece which i had to take apart the trunk!
im just mad at this wind noise issue. i will try his fix and than move on to other trouble shooting to see how i can make it pretty much wind noise proof.
this car does have several design flaws and if they let me help them, i could make this car perfect!
thanks
