Low Coolant - Possible Causes??
most likely you have a simple leak in the cooliing system, check the hoses and cap for leakages, what kind of coolant are you using?
have you ever done a water pump or did the PO do it? i bet it's leaking.
you can always buy a cheap pressure tester and test the system. if it's a leaking hose or fitting, you'll find it. the water pump won't show up on a pressur test though. look underneath after removing the belly pan. yo ushould find coolant dripping from somewhere. follow it up; theres' your leak. if it's dripping from the crank pulley area, you need a water pump.
the rubber cap thats next to the coolant cap..
OP mine leaks too, but i just keep an eye on it. ill replace it soon enough.
It could be the sensor's O-ring causing the leak, or the tank is cracked:
Coolant Tank Leak
In post 7:
This fixed my leak.
An obvious coolant leak is easy to smell on a warm engine and most instances of that, there will be puddles/drips. Barring those it's going elsewhere and yours doesn't sound good.
The car runs normally, the temp gauge starts out cold (normal) and moved up to midpoint normally (it stabilized a little past the second white marker...so near the middle between cold and hot). I got out to look at the exhaust pipes and the exhaust was whitish for about 30 seconds, after which it cleared up. Car was sitting out overnight, so I think that was condensation. At least that is what a dealership told me when I asked them about that ages ago. I drove about a quarter mile (slow 'in traffic' speed), then got out to look at the exhaust. There was too much white in the exhaust, but again, that cleared up later (I checked several times throughout the drive).
I looked all over under the hood and under the car. I don't see any big splashes of anything, though there is fluid around the reservoir cap (not the coolant cap, the rubber cap next to it). It seems limited to the top, though, and is not dripping down the sides. I've looked at the hoses (as much as I can figure out where they are, and do not see any leaks. I am not a mechanic so have no idea how to loosen it to check the entire reservoir for cracks or how to check the sensor's o-ring.
Read the manual and checked the engine oil accordingly. The oil looks fine; it's brown, not clear, but also not milky at all. It's just dirty. It's a reminder that it is time for an oil change.
The only other thing I saw was across from the reservoir, on what I think is the transmission, I saw seepage (not leaking) along a seam. It's best described as dampness of about 1/3 inch width running along the seam. Probably not a good sign, but isn't gushing by an means. Minor seepage best describes it.
I haven't been able to locate the receipt just yet, but I did have head gasket seals (?? I think that is what it was) replaced about four years ago at the dealership. Cost around $500 if memory serves.
I ran the A/C and it worked normally. Cranked it down to 69 degrees and it got really cold. I did not use the heater (hot here today).
So I will check the level again tomorrow. If it's low again, I will get it in someplace ASAP for diagnosis. Glad it appears to be driveable right now.
The only thing I can think of that I did differently (recently) was drive the car with the A/C off. I almost always have that on, for better air quality. Would that have had anything to do with the shift in coolant levels?
Thanks for everyone's comments. Very helpful. I hope it is something simple like that sensor's o'ring. I'll post back here to let you know what happens.
Coolant Tank Leak
In post 7:
