Chirping sound at iddle
Old Feb 26, 2009 | 08:01 AM
Pescao's Avatar
Pescao
Default Chirping sound at iddle
Hello everybody,
I have a good one here, I have this chirping sound when my RX its at iddle and cold. I thought that it was the belt, so, I put some belt dressing but the sound didn't go. I'm guessing that is a bearing from the alternator. Anyone had this problem before?
Thanks
Old Feb 26, 2009 | 08:04 AM
lexus114's Avatar
lexus114
Originally Posted by Pescao
Hello everybody,
Thanks
Sounds like you might be on the right track. I have experienced this on a previous vehicle before. Could also be an idler pully,water pump,(although doubtful) did you spray both sides of the belt?
Old Feb 26, 2009 | 11:30 AM
thomas1's Avatar
thomas1
Can you twist the belt a full 90degrees, if so it is too loose....
Old Feb 26, 2009 | 11:58 AM
bob2200's Avatar
bob2200
I had the chirping, had the belts replaced, and it went away.
I'm not saying that tightening the belts won't also temporarily cure the chirping; but, if the belts are over 5 years old, I'd just spring for new belts.
Old Feb 26, 2009 | 04:37 PM
habeeb89's Avatar
habeeb89
I had the same problem, it went away after replacing the drive belts.
Old Mar 2, 2009 | 07:58 AM
Pescao's Avatar
Pescao
The belt is relatively new (less than 2 years) but I will replace it anyway. Let you know if that was the problems.
Thanks everybody
Old Mar 2, 2009 | 07:30 PM
powerslide's Avatar
powerslide
I had to retighten mine for that noise. the new belt will stretch after a while. It is not fun to tighten it.
RookieLEX
Jun 5, 2017 11:37 AM
tsslaporte
Nov 8, 2010 10:12 PM
underpsi
May 6, 2007 12:21 PM
BlkGS3
May 25, 2005 08:59 PM
brendanlim
Performance
Aug 19, 2002 01:26 PM
