Lexus Expands F-Sport Performance Line to Include Parts for GS, IS C and IS AWD
Old 02-11-09, 12:07 PM
GFerg
Speaks French in Russian
Senior Moderator
GFerg's Avatar
Default Lexus Expands F-Sport Performance Line to Include Parts for GS, IS C and IS AWD
Torrance, Calif., February 11, 2009 -- Lexus today announced that it will expand its popular F-Sport Performance Accessories line. The luxury manufacturer launched its signature line of sport performance parts last spring with accessories for the IS 350 and IS 250 entry luxury sport sedans. The line will soon include F-Sport parts for the current generation GS luxury sport sedan, IS all-wheel drive (AWD), and the all-new IS C convertible coupe models. F-Sport equipped versions of the GS, IS and IS C will be on display at the Chicago Auto Show.
“F-Sport Accessories offer Lexus owners the ability to customize their vehicles to the next level of performance,” said Brian Bolain, Lexus national manager of marketing and lifecycle strategy. “Following last year’s successful launch of accessories for the IS 250 and 350 sport sedans, it was natural to expand the F-Sport accessories lineup to other Lexus performance models.”
The GS, IS AWD and IS C F-Sport accessories will include performance enhancing parts such as forged alloy wheels, brake upgrades, suspension systems, air intake, exhaust systems and more. Parts for these new models will be available as early as June 1, 2009.
F-Sport Performance Accessories by Lexus USA are engineered by Toyota Racing Development (TRD). When installed by an authorized dealer, the accessories are fully warranted for 12 months or for the balance of the new car warranty, whichever is greater.
F-Sport 18 and 19-inch Forged Alloy Wheels
The F-Sport forged alloy wheels, exclusively designed in a dark graphite finish, not only add an aggressive look to the exterior, but help enhance performance through increased strength and decreased weight. The F-Sport wheels require the use of spline-drive lug nuts, which are included in the available Wheel Installation Kit.
F-Sport Front Brake Upgrade
The Front Brake Upgrade provides a firmer pedal feel and improved fade resistance in repeated severe-duty use. The Brake Upgrade features six-piston fixed calipers and drilled cast-iron rotors with a patented internal-fin design mounted on anodized aluminum hubs. Braided stainless-steel brake lines and low-dust performance brake pads are included, and the upgrade can be used with stock or the F-Sport Rear Brake Upgrade.
Similar in construction to the F-Sport Front Brake Upgrade, the Rear Brake Upgrade uses four-piston fixed calipers and drilled cast-iron rotors. Braided stainless-steel brake lines and low-dust performance brake pads are also included. The Rear Brake Upgrade may only be used in conjunction with F-Sport Front Brake Upgrade.
F-Sport Shock Absorber Set
Developed in cooperation with Bilstein® and available exclusively through the F-Sport Performance Accessory program, this shock-absorber set offers sport-tuned suspension dampening without sacrificing ride quality.
F-Sport Lowering Spring Set
This feature lowers the vehicle approximately one inch in the front and rear for a more aggressive appearance and a lower center of gravity. The spring set is engineered to deliver lowered ride height without bottoming out or creating a harsh ride. The sets will be specifically configured for each model and can be used with either the stock or F-Sport Shock Absorber Set.
F-Sport Sway Bar Set
The sway bar set includes larger diameter replacement front-and-rear sway bars that reduce body sway and flatten cornering. Oil-impregnated rubber bushings are also included to replace the original rubber bushings. Each vehicle’s sway bar set is specifically configured to achieve the best performance.
F-Sport Rear Chassis Member Brace
To improve chassis stiffness under aggressive driving conditions and provide a more responsive feel during cornering, the F-Sport Rear Chassis Member Brace joins key rear-chassis and suspension mounting points through this tubular steel brace.
F-Sport Performance Exhaust System
This system features all stainless-steel construction with fully polished mufflers and double-wall exhaust tips. In addition to an outstanding appearance, it delivers a powerful, sport-tuned exhaust sound while complying with established sound-level standards and does not affect emissions compliance.
F-Sport Performance Air Intake
This low-restriction intake and filter assembly is fully compatible with stock engine controls and is emission legal in all 50 states.
F-Sport Carbon Fiber Engine Cover
Constructed from real carbon fiber, this light-weight, durable engine cover provides a high-tech appearance under the hood. This is a direct replacement for the original cover.
F-Sport Performance ClutchSet
The F-Sport Performance Clutch Set, available for the IS 250 and IS 250C equipped with the manual transmission, increases clamping force approximately 16 percent to handle higher torque capacity and provide improved feel.
F-Sport Quick Shifter
Engineered and machined from billet aluminum, the F-Sport Quick Shifter for the manual-transmission equipped IS 250 and IS 250C decreases shift throw by approximately 35 percent for quicker and more positive shifting.
F-Sport Shift ****
Constructed from premium leather and genuine carbon fiber, F-Sport shift ***** are sporty and offer a comfortable curved shape. The manual **** is weighted to provide a sporty and more controlled feel while shifting. Both ***** are detailed with signature blue stitching and a silver F-Sport logo.
F-Sport Floor Mats
Made from the same high-quality 18 ounce nylon carpet as the factory mats, the four-piece set is available in black with a silver embroidered “F-Sport” logo.
GFerg is offline
Old 02-11-09, 12:08 PM
MPLexus301
MPLexus301's Avatar
Holy picture batman.
MPLexus301 is offline
Old 02-11-09, 12:10 PM
bad co
bad co's Avatar
ugy blue seats
bad co is offline
MPLexus301
MPLexus301's Avatar
And FWIW, the GS should have different optional wheels. They need to get more serious about this stuff.
ISc looks good.
Old 02-11-09, 12:15 PM
habeeb89
habeeb89's Avatar
I wonder how much these cost... I'm actually a surprised they did a BBK for the GS.
habeeb89 is offline
Old 02-11-09, 12:20 PM
GFerg
Senior Moderator
GFerg's Avatar
LOL...sorry bout that. I didnt realize just how gigantic the pics would be.
I'm wondering if the blue leather seats will be an option. Not sure if I like that shade of blue on the interior though.
And it appears the GS has a bodykit as well.
GFerg is offline
dunnojack
dunnojack's Avatar
it's probably exactly the same as the one that has been out for the IS.
there's a body kit on that red GS, but no mention of it in the article.
it looks like the GS AWD is neglected yet again.
dunnojack is offline
Old 02-11-09, 12:24 PM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
Interesting.
More toys to put on the car if I want to Special Order one...
PhilipMSPT is offline
Old 02-11-09, 12:28 PM
IS-SV
IS-SV's Avatar
Sounds like the logical expansion of this product line if the F-Sport for IS cars has been successful.
IS-SV is offline
Old 02-11-09, 12:31 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
over here
https://www.clublexus.com/forums/gs-...or-the-gs.html
it says awd are included. that'd be good news for awd owners
there is no surprised for bbk on the gs. it's a known fact that the 2is and 3gs brake brackets are the same
only thing i wonder is the prices. some parts are more exclusive like the sway bars for the gs, there is no other companies with it
but stuff like springs, brakes, intake, etc... if they are not priced well, they are facing a lot of competitions out there
rominl is offline
Old 02-11-09, 12:46 PM
maying856
maying856's Avatar
Omg..................
maying856 is offline
Old 02-11-09, 12:50 PM
knihc2008
knihc2008's Avatar
No surprise here, IS and GS are on the same platform already anyway.
Are those blue seats on the IS-C for real? Is Lexus growing some ***** in the interior colors department?
knihc2008 is offline
Old 02-11-09, 01:03 PM
JessePS
JessePS's Avatar
How about...
GS-F
IS-F Coupe
LF-A (GT-F)
JessePS is offline
Old 02-11-09, 01:07 PM
dunnojack
dunnojack's Avatar
Originally Posted by rominl
over here
i mean the GS AWD for springs.
looks like lexus is still having trouble with that one
Koma
Koma's Avatar
Is the aluminum trim on the side skirt of the GS gun metal now?
Koma is offline
Quick Reply: Lexus Expands F-Sport Performance Line to Include Parts for GS, IS C and IS AWD
