Confusion over front differential vs transfer case
Had our RX on a lift to replace the fluids and was confused over location of the front differential and the transfer case. There is only one other drain plug besides tranny drain plug on the single assembly that may look like transmission, front differential, and transfer case combined.
Can anyone confirm or deny if the front differential is "built-in" the transmission so it is using the same ATF type IV fluid as transmission, and that other plug is a transfer case plug? '05 RX330 AWD
__________________
2006 TL NAVI 6spd
2005 RX 330 AWD NAVI
