IS F front rotors
Old 11-06-08, 05:52 AM
//LRD
//LRD's Avatar
Default IS F front rotors
Hey guys I'm running the LS caliper and I was wondering if any has tried the IS F rotors.I know I have to make a bracket to extend the caliber position.But other then that I not sure about the depth of the hat.
Old 11-06-08, 06:05 AM
Punky
Punky's Avatar
I could be wrong, but doesnt the IS-F have smaller brakes than the is350? And are you just swapping rotors or the calipers too? Either way you may find this link interesting https://www.clublexus.com/forums/sho...d.php?t=389600
Old 11-06-08, 08:06 AM
GSteg
GSteg's Avatar
IS-F brakes are marginally bigger than the IS350..it's not even close.
Not sure why you would want to use the IS-F rotors if you have LS calipers... Not like you'll be benefitting really.
Old 11-06-08, 08:30 AM
//LRD
//LRD's Avatar
I went online and check the spec's and IS f rotor 14.2 and IS350 13.What I really need is the hat size
Old 11-06-08, 09:09 AM
//LRD
//LRD's Avatar
no other reason but looks.I have 20inch wheels and the 12.40 LS rotors just look a little small.The car stop awesome.
Old 11-06-08, 09:12 AM
5sp_jzz30
5sp_jzz30's Avatar
bigger rotor translates to bigger lever arm for torque translation. when you apply the same force but over a longer distance it translated into more torque.
a lot of nissan guys run a 350z track rotor or the mustang cobra rotor. it is bigger then a regular z32 rotor and has shown to improve braking performance.
how mcuh are the is-f rotors? i doubt it is worth it. i can guarantee you that you will now exceed the performance of the TT brakes with right pads and rotors on the street.
Old 11-06-08, 09:33 AM
//LRD
//LRD's Avatar
Guys the car stops great not looking for more stopping power!but if I gain a little then thatz gravy.cross drills for my oe set up is bout 110.00 each still 12.40 the IS-F 190.00 each not a big diff.Customer of mine works for a Lex dealer and owes me big time,for a set of wheels I hook him up with.
Old 11-06-08, 09:41 AM
GSteg
GSteg's Avatar
When it come to fading, then yes, IS-F rotors may help, but I highly doubt stopping distance will improve. hardly worth the 'upgrade'
Old 11-06-08, 09:42 AM
GSteg
GSteg's Avatar
Well if you can fabricate an adapter for the calipers, go for it.
Old 11-06-08, 11:56 AM
//LRD
//LRD's Avatar
I already had them coming!I was trying to get a mental head start.So once I get them and figure out what has to be done.I'll post up the end result.
Old 11-06-08, 12:26 PM
YeA 2jZ
YeA 2jZ's Avatar
sounds interesting keep us informed on this project
Old 11-14-08, 09:10 PM
//LRD
//LRD's Avatar
Just pick up the IS F rotors from JM Lexus today and they just clear the tie rod end by 2mm but do clear.The Ls caliper contacts every inch of it.It's a perfect fit.All have to do is make the brackets.The mounting holes/caliper ears are about and inch a way.And there is a slight offset of the caliper which I will account for when making the bracket.I'll post pictures as soon as I get my cardboard template 3D scanned and made.It's going to work guys and the LS caliper looks bad @ss on it.
Old 11-14-08, 09:44 PM
shern
shern's Avatar
Luis at Carson had that group buy on the IS-F calipers/rotors for dirty cheap. There was talk about custom brackets for GS/LS/SC to mount those bad boys but nothing every materialized.
Old 11-14-08, 10:08 PM
YeA 2jZ
YeA 2jZ's Avatar
oh man i cant wait to see this
Old 11-15-08, 11:15 AM
5sp_jzz30
5sp_jzz30's Avatar
how much are the is-f rotors?
Quick Reply: IS F front rotors
