CUT & Program any LEXUS KEY without DEALER
Last month I purchased my 04 Lexus RX330. I only got 1 master Key. Like everyone esle, I searched the web for a way to cut and program it. I called the dealer and they said ...the key must be purchased and program through the dealer ...or else it will not work. THIS IS WRONG. They LIED.
Yes they do need to make a living but...doesn't have to lied and be unethical to the customer.
I ordered two keys from ebay for around $65.
I called my local locksmith ...from Minnesota...
I meet up with him at Perkins...and he cut the key with a regular grinding machine...that copy the pattern to the orginal. (Anyone said that it must be cut with a laser cutter is...WRONG)
The guy cut the two keys in 15min.
He had a small hand held device that hook up to the bottom of your driver dash.
Programed the two keys ..with locks and rear auto doors ..within 15mins...
The whole entire entire procedure takes about 30 min total.
Total price for each key to cut and program ? $50.
So my total price for both keys was $100.
I suggest you all to get a good key from good ebay seller...
Then call your local locksmith to have him cut and make to ask if he have a key programer. Chances are..you can get it done easily ..with out the Nasty Dealer ripoff price.
ONCE and FOR ALL..
Last edited by Lil4X; Oct 25, 2008 at 06:25 AM. Reason: Removing dead eBay link, telephone #
Im not trying to defend the dealers, but im sure they will say most aftermarket keys wont work, but they are not going to try and test it out. If they do sell the keys there, they want you to buy theirs of course. They gotta make a living and eat too.
Anyway good that you got your keys for cheap. Do you mind posting who the seller ID of fleabay since I need a spare?
Thanks
eBay sellers come and go, and this one has evidently gone. They are probably good sellers, especially the storefronts, but they may be short of stock. Many of these sellers don't carry more than a couple of any one item and the auctions (and BINs) appear and disappear regularly. If you want to check out the availability of keys or other parts, it's best to do a search on RX 330 key in the eBay motors section.
Also, would a dealer program and cut the key, if we bought the key+transponder from Ebay? If so, how much?
Last week I bought a aftermartket key on ebay, and cut and programed by Lexus dealer. It worked. but I paid $73.
good luck.
The local dealership here in Calgary originally quoted me $360 for a programmed key.
Thanks in advance.
I have key's program for a RX:
Programming Procedure #21485
1. Drivers door open, all other doors closed, key removed from ignition switch.
2. Within 5 seconds insert and remove the key from the ignition switch twice.
3. Within 40 seconds close and open driver's door twice.
4. Insert and remove the key from the ignition switch.
5. Within 40 seconds close and open driver's door twice.
6. Insert the key into the ignition switch and close the driver's door.
7. Switch ignition on and off,
a) Once to program a remote transmitter code while retaining the original codes.
b) Twice to program a remote transmitter code while erasing the original codes.
c) Three times to check how many remote transmitters are currently registered.
d) Five times to erase all registered codes.
8. Remove key from ignition switch.
9. System should now lock and unlock vehicle. Once, twice or five times depending which mode has been selected. One to four times, slowly, to indicate number of remote transmitters registered.
10. Within 40 seconds press and hold lock and unlock key remote transmitter buttons, together, for 1.5 seconds.
11. Within 3 seconds press any key remote transmitter button.
12. System should now lock and unlock vehicle. Once to confirm registration, or twice to indicate registration has failed.
13. Within 40 seconds repeat steps 11 and 12 to program remaining remote transmitters.
***** To exit programming mode: Open driver's door or insert ignition key.
***** A maximum of 4 key remote transmitters can be programmed.
I got it when I buy a key on ebay, However I have not tried yet( a dealer did for me).
good luck.
RX330
Thanks!
good luck.
RX330
