List of RX300 DIYs
In order to make it easier for both new and veteran members alike, I'd like for everyone to add any DIYs for the RX300 in this sticky thread (maintenance, special projects, you name it) done by any of our members. I know I have a few myself, TunedRX300, our friend ederny, http://rx300how2.home.comcast.net/~rx300how2/ and many others. It is not necessary to have done them on Club Lexus, we only need a link to the thread or site.
Since many DIYs are based on check engine light (CEL) errors faced by RX300 owners, it would be helpful if everyone could take this survey of CEL so that we can pinpoint issues and keep them in mind when we do future DIYs, https://www.clublexus.com/forums/sho...d.php?t=329187
Oil Change,
https://www.clublexus.com/forums/rx-...il-change.html
Rear differential/Transfer case fluids (for those of you with an AWD RX300)
https://www.clublexus.com/forums/sho...d.php?t=214000
Door panel removal (includes link related to lubing window motor),
https://www.clublexus.com/forums/sho...d.php?t=288373
Removal of window motor along with door window (goes in hand with thread above),
https://www.clublexus.com/forums/rx-...r-removal.html
Aftermarket window motor and regulator (goes along with two threads above),
https://www.clublexus.com/forums/rx-...s-and-now.html
Shock removal and installation,
https://www.clublexus.com/forums/sho...d.php?t=327873
Spark plugs removal (has link to separate throttle body removal to get to them easier)
https://www.clublexus.com/forums/sho...d.php?t=264967
Throttle body removal (actually how to open it to get at spark plugs easier),
https://www.clublexus.com/forums/rx3...ark-plugs.html
Brake pads,
https://www.clublexus.com/forums/sho...d.php?t=264864
Lubricating the brake pins and replacing rubber dust boots (goes with the brake pads DIY above)
https://www.clublexus.com/forums/rx-...ust-boots.html
Removal of center piece from steering wheel,
https://www.clublexus.com/forums/sho...d.php?t=315272
Disabling DRLs (Daytime Running Lights),
https://www.clublexus.com/forums/sho...d.php?t=299658
Accelerator cable modification for better response,
https://www.clublexus.com/forums/sho...d.php?t=351073
Coolant changeout,
https://www.clublexus.com/forums/sho...d.php?t=249741
Locations of bolts to remove rear bumper,
https://www.clublexus.com/forums/rx3...r-removal.html
Cleaning the ABS wheel sensors,
https://www.clublexus.com/forums/rx-...when-rain.html
Changing the Oxygen Sensor located after the main catalytic converter (Bank 1, Sensor 2),
https://www.clublexus.com/forums/rx-...sor-2-diy.html
Replacing the radio antenna mast,
https://www.clublexus.com/forums/rx-...enna-mast.html
I will add more over time as I do them.
https://www.clublexus.com/forums/rx3...-write-up.html
CAI
https://www.clublexus.com/forums/sho...d.php?t=158249
Power Steering Fluid Flush
https://www.clublexus.com/forums/sho...d.php?t=224976
AC/Alternator Belt Adjustment
https://www.clublexus.com/forums/sho...d.php?t=272697
Transmission Fluid Flush: already a sticky, thanks to Lexmex
https://www.clublexus.com/forums/sho...d.php?t=220061
Bleeder Screw
https://www.clublexus.com/forums/sho...d.php?t=185967
https://www.clublexus.com/forums/sho...d.php?t=295546
I am also adding these that I found and remembered
Aux in for RX300 (tomv), https://www.clublexus.com/forums/sho...d.php?t=215793
and
Center console removal (Shonuff), https://www.clublexus.com/forums/sho...d.php?t=290465
Let me know if anyone knows of any other DIYs, even ones such as audio or lighting, not just maintenance.
Window switch lights to LED (Will49), https://www.clublexus.com/forums/lighting/99841-rx300-interior-green-to-white-led-conversion.html (thanks to YoshRX300 on this one)
https://www.clublexus.com/forums/sho...t=77510&page=3
and see post 35 from this thread, https://www.clublexus.com/forums/3946871-post35.html
Also, https://www.clublexus.com/forums/rx-...-cold-air.html
https://www.clublexus.com/forums/rx-...el-sensor.html
How to test air/fuel sensor
https://www.clublexus.com/forums/rx-...esistance.html
Last edited by 81corolla; Oct 15, 2009 at 08:07 PM. Reason: Added link to test sensor
In the workflow, it says to put the cable with the teeth facing the rear of the vehicle...I tried this for about a half an hour to no avail...then for the H*** of it I turned the teeth towards the front of the vehicle, and the antenna motor took the new mast the first time.
The instructions were from the shop manual, and so I don't understand why the discrepancy, but I just wanted to make everyone aware.
Happy New Year,
JBL
