IT's Here 2jzgte vvti & Garrett GT3582R
-Taylor
I need that CRANKSHAFT PULLEY (SST09213-70010, 09330-0021) to remove the crankshaft bolt.
STU said that with his hydrid CT12b USDM turbo set up. I could make a reliable 450whp at 18psi. That's good enough for me.
SEE LINK BELOW:
http://www.97supraturbo.com/
His site has a lot of good information & pictures & videos
1: ARISTO 2jzgte vvti & SC300 2jzge vvti shipped to Phoenix Tuning for hybrid harness conversion
2: Removed Transmission
3: Removed Crankshaft Pulley
Parts Ordered
1: Supra Turbo Oil Return Flange
2: Turbo # 2 Oil Return Line
3: Oil Return Hose & Clamps
I am now able to order the Water Pump, Timing Belt, Cam Seals ,Front Seal ,Rear Seal. I did not think I would be able to remove the Crank Shaft Pulley Bolt. With my wife's help and a bar that I attached to the rear of the engine with the fly wheel bolts and a breaker bar with a jack handel (2ft) it came off very eazy.
Next On The List
1: Remove Sump
2: Attach Super Turbo Oil Return Flange
3: Wait For Hybrid Harness
4: Look For 2jzgte vvti ECU
Parts Ordered
Next On The List
1: Remove Sump
Link: http://cgi.ebay.com/ebaymotors/2JZ-G...d=p3911.c0.m14
