Help! Pcs Check System Cruise Check System Errors!
Ok. I am driving home after dark last night in the middle of nowhere which is easy to do in Kansas. As I go around a left hand curve my laser cruise shuts off, this awful red upsidedown triangle appears and the above errors pop up.
I pulled over, shut off the car, restarted but the PCS system and Laser cruise errors are still in place and they cannot be used. When I got home I cleaned the lens cover too.
I can use the regular cruise IF as soon as I start the car I push the cruise button on and then cancel the Laser cruise, but the PCS error is still there.
What should I do? There was no impact of anything of the sort. the stealership wants $70-$130 bucks just to diagnose the problem.
Is there a manual reset? Thanks in advance for any help.
