LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
HID Installed in 04 LX470
Old Feb 20, 2008 | 11:18 PM
synacide's Avatar
synacide
Lightbulb HID Installed in 04 LX470
Ive installed HID with 6000K bulbs using the DDM kit found at ddmtuning.com.
I drilled a 3/4" hole in the back of the plastic cover that houses the H1 bulb to allow for the wires to pass through the housing as seen in the pictures below. I took apart the wire from the plug harness in order to pass the wire through the hole. The size of the plug harness does not allow this to happen without doing so. Just feed the rubber grommet through the hole for a watertight seal. I connected the leads to the inside housing connection and used heat shrink tubing over the connection. The H1 HID bulb fits and clips onto the housing without any modification to the bulb holder as opposed to other installs seen by other HID kits.
After all that, its just plug and play. Take a look.
Old Feb 21, 2008 | 07:42 AM
adam4x4's Avatar
adam4x4
So how is the lighting? Do you like them? Looks to be an easy install and very clean.
Old Feb 21, 2008 | 07:45 AM
synacide's Avatar
synacide
The lighting is excellent. Much Brighter than stock and this is the way it should have come from factory. The projector really helps the lights giving it a very good beam pattern lighting up evenly.
Old Feb 21, 2008 | 11:07 AM
davidsong's Avatar
davidsong
looks nice, but i dont like drilling in my car, so i just replaced my stock bulb with Sylvania Ultra Star bulb. its much better than stock, and the color is brighter...
but anywz, good job on ur clean work. looks real good
Old Feb 24, 2008 | 09:22 AM
RXGS's Avatar
RXGS
^^^ hey, i know tyhis is a stupid question to ask, but what kind of bulb does the lx use? im going to walmart today so if i know, i can just pick up a set of sylvania's
Old Feb 24, 2008 | 09:26 AM
synacide's Avatar
synacide
mine uses H1 bulb.
Old Feb 24, 2008 | 10:27 AM
davidsong's Avatar
davidsong
drl/high beam 9005.
low beam H1.
i used 9005SU(silverstar ultra) and H1. Because sylvania dont carry ultrastar for the low beam, i just use H1ST(H1 silverstar high performance lighting).
Old Feb 25, 2008 | 08:06 PM
RXGS's Avatar
RXGS
that you very much, now is that the one with 3 plugs or 2 plugs on the bottom? sorry i m asking these stupid questions, i know more bout the es then i do the lx
Old Mar 24, 2008 | 12:00 PM
umnitza's Avatar
umnitza
Bavtoys has these for $100 + shipping.
http://forums.bimmerforums.com/forum...d.php?t=946796
Old Mar 27, 2008 | 10:17 AM
jjbenzo's Avatar
jjbenzo
Looks great! I did the same thing when I installed HID's in my Lincoln LS. HIDs didnt come out on the LS till 03. I dont recall drilling a hole to make the wires pass through though.
Old Mar 30, 2008 | 05:54 PM
firetora's Avatar
firetora
i installed them but I got them from bavtoys
i liked them so much, i'm going to start vending them here
Old Apr 1, 2008 | 03:29 PM
joe42276's Avatar
joe42276
I installed HID setups (4300k) on both headlight and foglights. It made a world of difference! The headlamps also lit up with 2 oval slots from each headlamp. This caused some drivers to be annoyed, and also looked funny when you see the light cast on a wall. This was simply solved using a bit of 15 minute JB Weld kit... and a pair of disposable chopsticks =)
Now the lights cast look clean, and nobody has complained about the brighter lights!
Old Apr 4, 2008 | 02:35 AM
GSteg's Avatar
GSteg
Got any picture of the beam pattern against a wall? Ever thought about replacing those parking lights to match the HID color? I think it would look less disoriented that way.
Old Jan 30, 2009 | 10:47 PM
azaytsev's Avatar
azaytsev
I have the same problem. Can somebody explain me how to fix this. The light output looks very strange.
thanks
Old Jan 30, 2009 | 11:26 PM
rueym's Avatar
rueym
i've had belloff HID's in my car since 03 and they are , the two oval slots on the beam pattern are mostly for signs when it is down the road.
