Unilateral AFS (Adaptive Front Lighting System) ?
Old 02-05-08, 07:26 PM
tawm
tawm's Avatar
Default Unilateral AFS (Adaptive Front Lighting System) ?
I noticed tonight driving home in the fog that my headlight AFS (Adaptive Front Lighting System) is much more noticeable on the left than the right side. Turning left will aim the headlight significantly left, but turning right yields much less light to the right. I assume the system works by raising a small mirror to reflect more light to the side as one turns.
1) Has anyone noticed such an AFS imbalance?
2) I was leaving AFS on all the time since it's very handy for driving at night. Or is AFS something that can wear out easily, and should only be turned on when needed?
Old 02-05-08, 07:29 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
It's normal, not an imbalance. AFS System is designed that way.
In a left-hand turn, the left headlamp will pivot up to 15 degrees (the right-hand headlamp remains pointed straight ahead) and in a right-hand turn, the right headlamp will pivot up to 5 degrees (the left-hand headlamp remains pointed straight ahead).
Old 02-05-08, 08:52 PM
Booyah
Booyah's Avatar
If I remember correctly you can turn it off but it will reactivate above 15MPH I believe. I would have to check the manual but its in there
Old 02-05-08, 09:36 PM
tawm
tawm's Avatar
Default Thanks Dave and Booyah!
Thanks Dave -- I am still trying to understand the logic of having lower deflection for turning right than left.
Thanks Booyah -- as I recall with AFS on, it will activate at higher speeds; but with it off I think the lights stay straight ahead. My question is if leaving AFS on all the time puts inadvisable wear and tear on the mechanism.
Old 02-05-08, 10:22 PM
Booyah
Booyah's Avatar
Loook in the manual--Im sure if you turn them off they will reactivate themselves--go look it up
Just leave them on, you are not hurting anything
Old 02-05-08, 10:44 PM
charley240
charley240's Avatar
im not positive, but logic tells me it does it that way because of beam pattern cutoffs. someone else?
Charley
Old 02-05-08, 11:57 PM
RXSF
RXSF's Avatar
i believe they stay off actually if you push the button.
what happens is the bulb actually turns with the wheel. Im sure using and using it will cause wear and tear, but it doubt its enough to notice. I leave mine on all the time, and they seem to be working.
Old 02-06-08, 05:37 AM
mandyfig
mandyfig's Avatar
Those Adaptive lights are designed where if they failed...like stuck to either side, coverage is still within the spec....just another item to consider on the FMEA, Failure Mode Effects Analysis.
Old 02-06-08, 08:49 AM
Grumpa72
Grumpa72's Avatar
My 05 330 does exactly the same and that is normal, as others have stated. In addition, this topic is covered fairly well in the manual.
Is the ability to turn off the AFS something that was NOT available until after 2005? When we bought our car new, we both read the novel (way to big to be a manual ) and even spent time in the car, learning switches and such. I have no recollection of an on/off switch for the AFS.
Gary
Old 02-06-08, 10:23 AM
RXSF
RXSF's Avatar
its near the buttons for adjusting your outside mirrors, near the trunk auto lid open/close button, and the gas cap button. basically, its on that panel. lol. my 2004 has it
Old 02-06-08, 01:13 PM
Grumpa72
Grumpa72's Avatar
Cool. Thank you for that. I will look that one up and impress my wife, who claims to know more about this car than me! Oth, this is her car; mine is a new BMW 328.
Old 02-06-08, 04:47 PM
sama
sama's Avatar
Gary
This is the AFS switch on 07/08 RX
Attached Thumbnails Unilateral AFS (Adaptive Front Lighting System) ?-swich.jpg
Old 02-06-08, 05:40 PM
mandyfig
mandyfig's Avatar
There you go, sama's done it again!
Old 02-19-08, 12:15 PM
Frankr66
Frankr66's Avatar
dont worry about turning them off until you reach 50K lol
Old 02-19-08, 03:00 PM
jlawr
jlawr's Avatar
The reason the lights deflect more to the left is that you are crossing a lane of traffic if you are turning left on a two way street. When you make a right turn you don't cross any lanes of traffic so less deflection and illumination is needed.
I wonder if the 15 and 5 degree deflection is reversed in the UK, Hong Kong and Japan, since they drive on the "wrong" side of the street in those places.
Quick Reply: Unilateral AFS (Adaptive Front Lighting System) ?
